Help me fix the S
I have a 993 Carrera S. The S lettering cracked. How do I remove the remaining S and replace it? Seems like the risk for damaging paint is high...
Old 08-28-2014, 06:10 AM
If it's adhesive attached, you can saw it off with dental floss.
Good luck
Dave
Old 08-28-2014, 06:21 AM
Tim/oh's Avatar
Not sure how they are attached, most nameplate/emblems are 2 side taped on. If that is the case and you are talking about removing the adhesive go to any automotive paint store and ask them for a stripe removal disk. It's a small wheel that is made of a material similar to a pencil eraser, it can be attached to a drill and will remove stripes, 2 side tape etc..... It will not damage the paint unless you have an old car with no clear coat or a cheap paint job.
Old 08-28-2014, 06:23 AM
PeteM1965's Avatar
Park car in sun to soften up adhesive. Mask area around the letters you want to remove. Take dental floss and working it back and forth in a sawing motion you should be able to remove the letter. Then use an adhesive remover, alcohol or gasoline works for me, to clean up the area.
Old 08-28-2014, 06:52 AM
I've also used fishing line instead of the dental floss trick, but - same idea: warmth, sunlight, sawing motion...
Clean up the remaining adhesive with goof-off: it has worked well for me...
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html
Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things.
Old 08-28-2014, 07:07 AM
that worked! thx
Old 08-28-2014, 04:28 PM
