-   -   reference sensor connector (http://forums.pelicanparts.com/porsche-911-technical-forum/827359-reference-sensor-connector.html)
jeffs targa 08-28-2014 02:12 PM
Help, The connector to my reference sensor is missing the female end plug all the is now is small staycon type which one is broken any ides to replace /repair it?
I am trying to upload photo if can help .
Good news i found to no start problem :rolleyes:
jeffs targa 08-28-2014 02:20 PM
http://forums.pelicanparts.com/uploa...1409260755.jpg
Here is photo hope this is ok :)
steely 08-28-2014 03:26 PM
Confirm this first.
Junior timer connector from Eagleday.
AMP Connectors/Terminals
cabmandone 08-28-2014 05:58 PM
Maybe try the used parts forum to see if someone will part with one from an old harness??
jeffs targa 08-29-2014 03:02 AM
Thanks, steely looks like they just fit the bill there is a electronic supply house here in Albany that also may have something that will fit guess its worth to give them a shot.
As you can see the female side is gone.I have had the car for a year now still much to learn.:)
Flat6pac 08-29-2014 01:55 PM
connector
I have one and notes because I had a problem with the female side collapsing inside the connector. My notes are only from the day I did the job and the replacement piece is not proper color code but notes have the correct color code for the particular part I was replacing.
There is a 50/50 chance its what you need.
I PM ed my phone number to you
Brucehttp://forums.pelicanparts.com/uploa...1409345427.jpg
http://forums.pelicanparts.com/uploa...1409345692.jpg
