Raise or Roll - Seeking Advice
Hi All,
Big decision. My car is lowered quite a bit, enough that I get some rubbing on the right front tire. ![]() So the question is should I roll the fenders or raise it up a bit. The concept of hammers on my fenders has me a bit worried. Would appreciate some advice - has anyone else had their fenders rolled on an '80s 911? Happy with the results? I'm leaning towards raising the car back up a bit. |
great looking car! keep in mind you will need to get alignment done if you raise it..
the back looks really low, might look funny if you raise the front any more. did you measure fender heights on both sides? are they even? do you get bump steer at this height? I would look at rolling fenders, I'm going to do mine but i have 17x7s, they look like 16x6s on yours...\ my opinion
82 SC Targa Guards Red = Toy 04 E55 AMG Brilliant Silver = DD 04 Cayenne Turbo Platinum Grey on 22s = Previous DD 80 Wide body 12AT RX7 Black 350+ hp= Previous Toy 78 Alfa Romeo GTV Blue = My 1st Cool Car |
Thanks!
Yeah - alignment would be needed. I guess I would raise the whole car and not just the front. Rolling is not reversible so it has me a bit worried. Can always raise it look at it - if I hate it put it back and go for the roll. |
You need to see why you are rubbing. Too low? Not enough camber? Need more T-bar?
I had a similar issue which I solved by going to "turbo t bars" and a good performance alignment. |
cutting the lips down rather than rolling them is a better option IMo as it saves the paint
82 SC , 72 914 |
Raising the back is more involved than doing the front, if you are happy with ride height I would look at camber and fenders
Thanks for all the great advice. I'm mostly leaning towards raising the car because I haven't found any pics of a similar year 911 with rolled fenders so I can see what it looks like. I think in this month's Eurocar magazine there is a pic of one, but hard to tell.
Rolling the fenders would also require a paint job on the fenders. Metal is too think to roll and needs to be hammered. Does that sound right? |
Platinum Member
However, i'm probably one of the few around here that is not a fan of lowering street cars too much, especially if the rest of the suspension was not refreshed and stiffened. Driven too many cars that when lowered introduced unforeseen issues, like the front suspension bottoming out under aggressive braking, which becomes dangerous. |
I rented a roller and rolled my fronts with no issues.
I just rolled my fenders last week. I have 17x7 euromeisters on the front . I used a piece of 1-1/2" dia PVC plumbing pipe and a heat gun. I was dreding it but it went well no painting of the fenders. Very easy to do Just take it slow and you can see how the metal bends.. Slow and steady. Roll the fenders looks better lowered.
I have used a wooden base ball bat on all my cars, with very good result. Get the bat between the whel and the fender, and roll the car back and forth, so the bat rolls between the tire and the fender. Adjust the angle of the bat to match the fender. To me it also seems like the whole fender (font and rear) is pulled out a bit, so it's not only the lip that is flattened. This makes even more room. Easy and cheap!
My '87 Carrera NB is lowered considerably, and I'm running 7.5x17ET35 w/225/45-17 and 9x17ET16 w/255/40-17, and with 22mm spacers on all four heels. No rubbin issues! |
if its not a DD, how about some camber plates...
Couldn't resist:
'84 Carrera Cabriolet |
muck-raker
What a coincidence, I just finished rolling my fender lips this afternoon. MUCH easier than I thought it would be, and I didn't even crack my paint. I only had to spring for a wooden bat, $12 at WalMart (or "Wally Martinez" in these parts).
I have a heat gun, so I warmed up the area that I was about to roll, then gently rolled in 4"-6" increments. VERY happy with the results. I highly recommend 2 things: 1) Go to YouTube on DIY Fender Lip Rolling, and 2) Absolutely do not take a mallet to your fender lips.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA |
ROW '78 911 Targa
Factory euro ride height works for me...
Banned
Your front doesn't look that low, the tires look too big to me.
Maybe smaller front tires would be a better choice. What size front tires do you have on there? |
Under the radar
+1^
Has the tire grabbed the fender lip and bent it? If so you may as well roll the fender lips. Do your front shocks bottom out when you hit bumps? Then raise it up some. Probably should address the alignment as well. Also check the ball joints and suspension bushings. I had a loose ball joint which caused my tire to rub. Good luck,
Banned
My car is pretty low. 24" all the way around. I'm on 6" fronts and 7" rears, 16" rims. I have 225/50 in the rear, 205/50 in the front.
No issues with rubbing. I think you should check your front tire size. Maybe scale it down a bit. I did get an occasional rubbing in the rear when I was at 23 3/4". |
