MJ MJ is offline
Question What kind of plug wires do you recomend?
OEM or aftermarket? Mine are glowing. Thanks.
MJ
Old 09-16-2001, 03:23 PM
91C2wrencher's Avatar
Post
I just put in a set of Karlyn wires from Pelican, Nice set of wires all marked like the OEM ones, I did notice a little radio interference, but that's ok 'cause I never listen to the radio anyway, and they made a real difference in restoring some zip to my 3.6
Old 09-16-2001, 05:39 PM
Senior Member
Doug Zielke's Avatar
Post
I bought the OEM Beru set this year. There are cheaper ways to go of course, but they fit exactly, have the RFI suppression braiding, and quality connectors. My original set lasted 20 years...what more can you ask for?
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
"If it ain't broke...we'll help you fix it 'til it is!"
Old 09-16-2001, 05:45 PM
Eric Coffey's Avatar
I would stick with OEM Beru wires. Most aftermarket varieties cant handle the heat levels, and/or are cheaply made.
-Eric
Old 09-16-2001, 06:41 PM
Post
All ignition cables glow with an induced surface charge and will not be eliminated with the installation of new OEM or aftermarket cables.
If, on the other hand, you insist on replacing them, as a feel good thing, then prepare to be disappointed when you turn off the lights in your garage to see the light show continue.
Joe
Old 09-17-2001, 08:08 AM
Post
You can't do better than Magnecors. They make their own connectors rather than using the lousy Beru items.
Stephan
Old 09-17-2001, 03:03 PM
