R12 to 134a
I'm switching over to 134a connections so I bought a little kit from Pep Boys to change over the connectors. Trouble is on my Nippondenso the threads are both the same for the high and lo side. The lo side adapter goes on just fine but the high side adapter will not fit. Does anyone know a source where I can get a high side adapter to fit my compressor?
Heck, I’m only 5 not 71!
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Unless you are a certified A/C technician converting an R-12 system to R-134a is by no means a DIY project. Other than it being illegal to just "dump" the R-12 refrigerant, the big problem is somehow removing ALL of the R-12 refrigerant compressor lubricating oil that is NOT compatible with R-134a.
Hi Nick,
The correct service ports are an important part of the conversion process. I would order a steel set from ackits.com. You should pull the Shrader valve cores on your manifolds and install theses ports. They are both the same size, I think 1/4", and they come with a thread locker, and good caps. This is one of the first and easiest steps in the conversion. As Mr. Wwest points out, you need to find a way to flush the old mineral oil out of the system and replace with Ester oil. In general the components such as condensers, evaporator must be removed to flush properly. The compressor is simply drained of oil, filled with ester oil, then this is repeated 3 or 4 times, not flushed. A new receiver drier is added. Next you must address leaks. New O-rings compatible with new system are needed at any connection that is opened. This would be an acceptable minimal conversion and ignores old vs. new hoses, and does not address condenser or evaporator capacities. There are a number of vendors that provide kits to accomplish this. It is hard work, but rewarding. Good luck, Dave |
I have posed this question before, elsewhere....
With the compressor and R/D connections open, might it be possible to use compressed air to flush each section separately, not pressurize, just provide enough forceful airflow for long enough to be relatively certain the R-12 oil is fully purged. |
Still, individually flushing is certainly better, and more thorough. Dave |
Holy Smokes!
If you read my post I'm just changing over adapter connectors. Or, maybe I'll just leave everything alone.
Member 911 Anonymous
Hey NT,
If you used ES12a, that can be safely leaked into the environment, it is just propane and butane mix plus pine scent. It is totally compatible to anything you decide to put into your system per the manufacturer. I even did this to my Lexus, had to replace the internal thermal switch, did not feel like buying R134a so I placed ES12a and it was even better than before plus used only 80% of the required fill. But I agree R12 is a complete another issue, need to have it recycled/disposed of properly :-/. I know PITA.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Dave |
Banned
Nick, have you considered SPAL fans added to your rear condenser? Hows about an octinary switch to control the SPAL fans, the tiny, engine compartment heater fan, a warning siren to alert you to possible oil seepage from yer system (because a drop or two more or less a/c oil than specified by the a/c gods and you and your system are ****ed!), a cattle prod to shock you in an appropriate spot whenever you consider working on your system since, heeeellooooooo, you're not an a/c certified technician, another warning device that shouts obscenities if you bypass the pressure switch in order to charge the system (SOP for those that do this kind of work, but a travesty according to a certain someone that has little to no experience with the matter), and of course to trigger a BS meter! Is that eight?
i have slid ruber hoses over the ends of the lines and tried to blow it into a container, still messy. this also needs to be done if a compressor goes bad. oh, remove/repace the expansion valve.
Functionista
Ugh. After doing a number of r134 conversions in different vehicles I'd suggest getting a set of manifold gauges and some r12 from Craigslist. It's not like there is a shortage of the stuff...
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Thanks Jim! I'm taking care of it all. Almost done. Thank you everyone.
Unless you're thinking of leaving the R-12 Schrader valves in place and using R-134a adapters on top of those. Then charge with R-134a on top of the residual R-12? 2 BAD ideas. |
Or is that SOP anyway? |
Banned
if you pull a vacuum and can get the gaug that measures the vacuum in microns, you can be certain it has no leaks. i am not talking about vacuum on the manifold set. i have one. if i pull a vacuum donw to 500-800 microns and it holds, it has no leaks.
