WTF? Aero Mirror Install Gone Wrong. Mysterious RHD Door on Passenger Side?
Hey guys,
Okay, weirdest thing I've seen on a car in a while. On my ROW '82 SC, I was swapping on my fancy new Aero mirrors. Driver's side went perfect, passenger side is a huge WTF. The Aero mirror does not fit in the new location at ALL. Upon doing some reasearch, the old mirror I pulled off is actually a 70's 924 mirror (not sure if it's drivers or passenger side). Upon further research, I noticed that the mirror location of the right had drive (RHD) and left had drive (LHD) mirrors are way different. It looks like I have a RHD "drivers" door on my passenger side, for some crazy reason. http://forums.pelicanparts.com/uploa...1410187909.jpg http://forums.pelicanparts.com/uploa...1410188034.jpg http://forums.pelicanparts.com/uploa...1410188065.jpg I'm a little upset, as I just paid plenty of money for these really cool mirrors and I'm stoked to put them on. But now is the tough part... How the HECK do I fix it? Can I swap the mirror base on the aero mirror with a drivers side unit to make it for my door? Door I have to swap my whole fricken door for a LHD passenger door? Or should I try and fill the holes and re-drill holes where they are supposed to be and repaint? |
Which one is your car? On the 911, the passenger side mirror is much further back on the door than the right side, If it was mounted symmetrically to the driver side, it would be obscured in a large part by the A pillar.
What mirror did you take off? |
The red car is mine. The blue on in the screen shot is how I determined mine is incorrect. You can also see that there is a hole still sticking out of the bottom of my 993 mirror.
You can also see the blue car's driver side is mounted much farther forward, similar to where my passenger side is mounted.
You may have an early door that wasn't drilled at factory?
http://forums.pelicanparts.com/porsche-911-technical-forum/677814-passenger-side-mirror-72-a.html |
Gotta fill and redrill and paint. Sorry to hear about your pia.
It seems like fill and redrill would be easiest and cheapest... But how the heck can I determine where to drill? I can use the gasket as a template, but I don't have another 911 available to reference where to actually place it on the door. |
I believe there is a template in the factory service manual for drilling out the passenger door. I'll try to look around for it tonight.
You'll notice on the drivers side that there is a reinforcement plate on the inside of the door where your mirror mounts on the drivers side. It won't be there on the passenger side. |
Josh, was your mirror added correctly? (In the right spot) or did you have to modify it?
Did you notice that your driver mirror was power adjusted and your passenger mirror was not? |
2 options:
1: As previously stated, fill, sand, paint, install properly 2: Get creative and fabricate a larger base that will cover those hideous holes that were drilled with less than a little love... Hint: You have nothing to lose with option 2 |
http://forums.pelicanparts.com/porsche-911-technical-forum/568308-want-replace-my-sideview-mirrors.html |
How do you know your RoW car is not originally RHD?
| All times are GMT -8. The time now is 07:04 AM. |
