No spark / question on wiring
Hi!
Car: Porsche 911 2.0T 1969 with CDI-unit original car/wiring as far I know…
Car almost completed after 18 year full nut and bolt restoration.
This is the last step before first start up after all these years however For starting I need a spark ;-)
So this is what I did/checked
After connecting wires as shown in diagram the following can be observed when contact in on (step before starting) :
CDI-unit is making high frequency noise.
There is voltage on the lead that goes to the distributor
There is voltage at the arm of the contact points when gap is open
There is no voltage at the arm when gap is closed
There is no voltage at the ignition coil input side (not when gap is open or closed…..?
SEE ATTACHED PICTURE OFF CURRENT WIRING DIAGRAM
What is wrong here?
Could it be wiring?
Any suggestions
In the drawing the part in the red circle…. What component is this? Should it be in or are the wires wrong connected here?
The other wiring I am quit confident…..
Thanks already!
Cheers,
Bart
Old 09-09-2014, 12:24 AM
T77911S's Avatar
that may be a speed switch.
your tach is wired wrong. unless it is different for 69, the tach is wired to the points, you have it the HV (450v) from the CD unit. i hope you did not hurt the tach.
oh, that speed switch is also wired off the points. there should only be one wire going to the coil, that is the HV wire from the CD unit.
i assume that speed switch is just a rev limiter. that may be history too.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-09-2014, 03:40 AM
pinning CDI-box
Hi
Stupid me, ay?
car electronics is not my strong point ;-)
So to be clear....
- I got a voltage over my breaker points which is wrong ok?!
- High voltage (450V) should be the blue CDI wire going to the coil positive lead?
- breaker points should not get any voltage but only opening and closing earth / mass connection
- Tach should be connected to distributor.
Any idea about pinning of CDI box?
If you look at it as mounted (ribs facing towards me) blue - red - black is that right?
Thanks!
Old 09-09-2014, 04:18 AM
T77911S's Avatar
blue line to coil only.
tach and speed thingy go to points. actually there may be a connection for them near the CD unit.
points are just a switched ground.
RACE CAR:: sold
Old 09-09-2014, 06:39 AM
Yeah, that's clear to me however I measure a voltage at the black wire coming from the CDI.....
It reads 12V....
Guess my CDI box is fried.....however it does makes the famous wining sound.
Any idea?
Old 09-09-2014, 09:19 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Terminal A at the CDI box will measure +12V (consider it an output of the CDI box). There is an internal resistor (either 33 Ohm or 100 Ohm to terminal B, +12V). When you ground Terminal A (points close) the box releases a spark. Try that first. If that doesn't work your box needs repair.
For good measure I would remove both the speed switch and tachometer so they don't interfere. They both could have been damaged by hooking them up to the HV output.
Regards,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 09-09-2014, 09:38 AM
T77911S's Avatar
what ingo said.
go ahead and connect it back up, without tach and speed sw. and give it a try
RACE CAR:: sold
Old 09-09-2014, 10:58 AM
