-   -   Simple injector extractor for K-jetronic (http://forums.pelicanparts.com/porsche-911-technical-forum/829473-simple-injector-extractor-k-jetronic.html)
woland 09-11-2014 10:40 PM
The fact
Since a month, my 911 Sc sounds like she was five.
Verified sparks and cables and everyhing electric I made a simple test: lift the car and running the engine for three-four minutes, I went under and touched each cylinder.
My third cylinder on the right was cold, so I concluded that something had to be wrong in the injector and decided to remove it to test (no one problem with ingnition in eight years, nor in the 5 previous K-jetronic equipped cars I had, so NEVER supposed need to remove the thing).
Disconnecting the pipe I descovered that the injector isn't screwed but stays in site by pressure and a fat o-ring and there was no effort to convince it to go out from the tight.
The fix
This is the extractor I made and tested with the deepest inyector that come out in no-time. The materials are an hydraulic connector with the same screw of the inyector (11 mm), a 6 mm. bar and a short copper pipe right to allow the passage up and down in hi inside of all the other stuff:
http://forums.pelicanparts.com/uploa...1410499789.jpg
http://forums.pelicanparts.com/uploa...1410499814.jpg
http://forums.pelicanparts.com/uploa...1410499836.jpg
http://forums.pelicanparts.com/uploa...1410499861.jpg
http://forums.pelicanparts.com/uploa...1410499883.jpg
http://forums.pelicanparts.com/uploa...1410499907.jpg
http://forums.pelicanparts.com/uploa...1410499943.jpg
http://forums.pelicanparts.com/uploa...1410499970.jpg
http://forums.pelicanparts.com/uploa...1410499992.jpg
Hoping the pictures will be clear and that it will help someone
A special thank to my Porsche-friend Vincenzo Siecola who gave me some precious inputs from the opposite side of Italy
Mike Czech 09-11-2014 11:01 PM
Nice, but a bit too high tech for me. I leave the injector connected and put a small open-ended wrench around the base and lever it up. Works for me.
- Mike
Cooper911SC 09-11-2014 11:07 PM
Very nice method! Allows smooth controlled extraction for really stubborn injectors.
Thanks for sharing! Great Pics.
Cooper
tazzieman 09-12-2014 03:14 AM
Gee , mine always just pull out by hand. Could be the spinach talking I guess ;)
But hat's off for the device
T77911S 09-12-2014 03:30 AM
yea, nice tool, but a 10 or 11mm open end wrench works, and if you have flexible fuel lines then bonus, you dont have to deal with fuel.
woland 09-12-2014 04:36 AM
Obviously tried with every wrench I have
No one touched the injectors in the last eight years. I didn.t know before
Anyway I strongly prefere that a stuff driving fuel in pressure will be tightly inserted
The Sierra Cosworth of my daughter's late boyfriend burned like a crisp for a stupid little pipe spit outside his housing
gazzerr 09-12-2014 12:46 PM
Great idea to get to that one deep in the back with so little room for sure.
boyt911sc 09-12-2014 01:38 PM
You've been out of practice........
Ty,
10 or 11 mm open wrench won't work. You need a 12-mm open wrench or an injector puller like this:
http://forums.pelicanparts.com/uploa...1410554097.jpg
http://forums.pelicanparts.com/uploa...1410554113.jpg
I like to replace the rod with a heavy duty cable so I could pull the injector at an angle instead of straight upward direction. How's your 930?
Tony
woland 09-12-2014 11:20 PM
The injector was blocked!
I still put in place it and the engine runs six, softly
Next monday I'll overhaul the other five
mrdieseldude 09-13-2014 06:04 PM
I've heard some guy get'em out with claw hammers:eek:
woland 09-13-2014 06:19 PM
Will you try first, in your (74) 911S? :rolleyes:
mrdieseldude 09-13-2014 06:26 PM
me no try... like your idea better.;)
