woland's Avatar
Simple injector extractor for K-jetronic
The fact
Since a month, my 911 Sc sounds like she was five.
Verified sparks and cables and everyhing electric I made a simple test: lift the car and running the engine for three-four minutes, I went under and touched each cylinder.
My third cylinder on the right was cold, so I concluded that something had to be wrong in the injector and decided to remove it to test (no one problem with ingnition in eight years, nor in the 5 previous K-jetronic equipped cars I had, so NEVER supposed need to remove the thing).
Disconnecting the pipe I descovered that the injector isn't screwed but stays in site by pressure and a fat o-ring and there was no effort to convince it to go out from the tight.
The fix
This is the extractor I made and tested with the deepest inyector that come out in no-time. The materials are an hydraulic connector with the same screw of the inyector (11 mm), a 6 mm. bar and a short copper pipe right to allow the passage up and down in hi inside of all the other stuff:
Hoping the pictures will be clear and that it will help someone
A special thank to my Porsche-friend Vincenzo Siecola who gave me some precious inputs from the opposite side of Italy
Paolo from Alps
1980 911 Targa SC 3.0 - Silver metallic
1980 Ducati Pantah 500 - Red
1989 Yamaha 500 "Tracker"
Old 09-11-2014, 10:40 PM
Nice, but a bit too high tech for me. I leave the injector connected and put a small open-ended wrench around the base and lever it up. Works for me.
- Mike
Old 09-11-2014, 11:01 PM
Cooper911SC's Avatar
Very nice method! Allows smooth controlled extraction for really stubborn injectors.
Thanks for sharing! Great Pics.
Cooper
Old 09-11-2014, 11:07 PM
tazzieman's Avatar
Gee , mine always just pull out by hand. Could be the spinach talking I guess
But hat's off for the device
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 09-12-2014, 03:14 AM
T77911S's Avatar
yea, nice tool, but a 10 or 11mm open end wrench works, and if you have flexible fuel lines then bonus, you dont have to deal with fuel.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-12-2014, 03:30 AM
woland's Avatar
Obviously tried with every wrench I have
No one touched the injectors in the last eight years. I didn.t know before
Anyway I strongly prefere that a stuff driving fuel in pressure will be tightly inserted
The Sierra Cosworth of my daughter's late boyfriend burned like a crisp for a stupid little pipe spit outside his housing
Paolo from Alps
Old 09-12-2014, 04:36 AM
Great idea to get to that one deep in the back with so little room for sure.
Old 09-12-2014, 12:46 PM
You've been out of practice........
Ty,
10 or 11 mm open wrench won't work. You need a 12-mm open wrench or an injector puller like this:
I like to replace the rod with a heavy duty cable so I could pull the injector at an angle instead of straight upward direction. How's your 930?
Tony
Old 09-12-2014, 01:38 PM
woland's Avatar
The injector was blocked!
I still put in place it and the engine runs six, softly
Next monday I'll overhaul the other five
Paolo from Alps
Old 09-12-2014, 11:20 PM
I've heard some guy get'em out with claw hammers
Mike
'87 911 Cab
'82 931
'74 911S Coup
'69 912 Coup
Old 09-13-2014, 06:04 PM
woland's Avatar
Will you try first, in your (74) 911S?
Paolo from Alps
Old 09-13-2014, 06:19 PM
me no try... like your idea better.
Mike
'87 911 Cab
'82 931
'74 911S Coup
'69 912 Coup
Old 09-13-2014, 06:26 PM
