-   -   best wideband O2 sensor/ system out there?? (http://forums.pelicanparts.com/porsche-911-technical-forum/829487-best-wideband-o2-sensor-system-out-there.html)
turbobrat930 09-12-2014 05:27 AM
Ok, guys... I have an Innovate LC-1, and am NOT impressed with it, its performance, or the company.
What do some of you run, and which ones do you swear by?
FYI, I really dont need a bunch of features, as my ECU does the data logging for me. I just want it to be accurate!!!
Pazuzu 09-12-2014 07:42 AM
Why? I haven't really heard anything bad about them or the LC-1, it's what I have. The only issues I have with it is that I have to babysit it every few months and do a free air calibration.
The only other one I can think of is an AEM system, I do not know what is considered their standard setup.
Wideband UEGO Air/Fuel Controllers | AEM
Lapkritis 09-12-2014 08:12 AM
I use LC1 and LMA-1/2 on different cars. They work fine; install properly then forget about it except for an annual free air calibration just for good measure.
Considering this for features and simplicity:
EAW-52 Wideband Controller | VEMS US
toddu 09-12-2014 08:55 AM
Do you need RPM also? Almost seems "useless" without it. (almost)
A lot of them do seem to offer RPM input as well, which seems necessary from a tuning perspective.
Todd
DUK 09-12-2014 09:01 AM
I like my innovative MTX. I was told it has a faster sampling time and newer technology than the lc1.
preston_brown 09-12-2014 09:02 AM
Check out products from 14point7. They have a bunch of very nice wideband O2 (UEGO) sensors and other stuff, for very very fair prices.
14Point7 | High Performance Tuning Tools for High Performance Engines
turbobrat930 09-12-2014 09:05 AM
Todd
No, my ECU (Link G4 extreme) has all of that. Just not happy with the Innovate. Was wondering what others are using.
toddu 09-12-2014 11:38 AM
Oh man... that iDash looks pretty intriguing.
Todd
dicklague 09-12-2014 03:15 PM
This is what I recommend. I have been running one for 5 years and love it.
Very high build quality, accurate. all in one unit.
http://forums.pelicanparts.com/uploa...1410560100.jpg
Daytona Sensors LLC - WEGO IV Wide-Band Air/Fuel Ratio Tuning Aid
Sold by our hosts by the way.
911pcars 09-13-2014 07:32 AM
Dick,
Sent you a PM
S
Trog 09-13-2014 08:04 AM
Excellent products, reasonable prices:
Wideband WBo2 2J2/9/P Technical Information (Tech Edge)
rsscotty 09-14-2014 02:42 PM
I have used this as needed for in car A/F measurements on engines with carbs or MFI.
PLX DM-6 SM-AFR | Wideband Air Fuel Gauge
Pstallo 09-17-2014 07:39 PM
Wideband installation
Does the AF gauge require a new O2 sensor bung placed in the exhaust in addition to the one there or can you hook into the existing wiring somehow?
Lapkritis 09-17-2014 08:04 PM
Stock o2 sensor on all except newest are narrowband. You can program the LMA output to mimic the narrow band and it has 2 output channels... So one can be wideband output too.
Pstallo 09-17-2014 08:13 PM
So, to get a REAL sideband reading, welding a new bung to the exhaust would be the best, correct? I assume it would need to be placed before the catalytic converter (or, in my case, the pre-muffler)?
Tippy 09-17-2014 08:32 PM
+1
Samples 1000 X's a second and the display will change tenths of an AFR faster than you can see/interpret.
toddu 10-22-2014 04:07 AM
Todd
To circle back on this, I did end up buying the 14point7 iDash. I've written up the installation and use as I wasn't able to find any reviews on it. So far I like it.
14point7 iDash Wideband Controller
Todd
Omegaman 10-22-2014 12:14 PM
I have 2 MTX's fitted to my V12 and they have worked perfectly for 2 years, the response is very fast. Recently one of the gauges has started acting up and I think one of the sensors is going strange. I've ordered a new one.
For the money I think innovate kit is good. Just make sure you mount your sensor a little way back from the header and in the upper section of the pipe....between 9 and 3 O Clock.
dicklague 10-22-2014 12:48 PM
Todd
How much did it cost?
Better than Daytona-Sensors WEGO IV?
toddu 10-22-2014 02:20 PM
Better? I'm not sure. It suites my particular needs better. All the information is up on their website - 14point7.com.
It seems to support a lot more inputs, a lot more display options, don't have to install the display, and uses the same Bosch sensor.
It's $299 for single sensor and controller, $399 for dual sensors.
Todd
