E-85 sippin drunk
best wideband O2 sensor/ system out there??
Ok, guys... I have an Innovate LC-1, and am NOT impressed with it, its performance, or the company.
What do some of you run, and which ones do you swear by? FYI, I really dont need a bunch of features, as my ECU does the data logging for me. I just want it to be accurate!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
The only other one I can think of is an AEM system, I do not know what is considered their standard setup. Wideband UEGO Air/Fuel Controllers | AEM
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Straight shooter
I use LC1 and LMA-1/2 on different cars. They work fine; install properly then forget about it except for an annual free air calibration just for good measure.
Considering this for features and simplicity: EAW-52 Wideband Controller | VEMS US
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Do you need RPM also? Almost seems "useless" without it. (almost)
A lot of them do seem to offer RPM input as well, which seems necessary from a tuning perspective. Todd
'81 SC |
I like my innovative MTX. I was told it has a faster sampling time and newer technology than the lc1.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Racer
Check out products from 14point7. They have a bunch of very nice wideband O2 (UEGO) sensors and other stuff, for very very fair prices.
14Point7 | High Performance Tuning Tools for High Performance Engines
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera |
E-85 sippin drunk
No, my ECU (Link G4 extreme) has all of that. Just not happy with the Innovate. Was wondering what others are using.
Todd
'81 SC |
This is what I recommend. I have been running one for 5 years and love it.
Very high build quality, accurate. all in one unit. ![]() Daytona Sensors LLC - WEGO IV Wide-Band Air/Fuel Ratio Tuning Aid Sold by our hosts by the way.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Dick,
Sent you a PM S |
1984-911 M491
1984-911 TLC......SOLD |
I have used this as needed for in car A/F measurements on engines with carbs or MFI.
PLX DM-6 SM-AFR | Wideband Air Fuel Gauge |
Wideband installation
Does the AF gauge require a new O2 sensor bung placed in the exhaust in addition to the one there or can you hook into the existing wiring somehow?
1986 911 3.2 Cabriolet "We all have a desire to create something that will show we were here. " Ferry Porsche |
Straight shooter
Stock o2 sensor on all except newest are narrowband. You can program the LMA output to mimic the narrow band and it has 2 output channels... So one can be wideband output too.
So, to get a REAL sideband reading, welding a new bung to the exhaust would be the best, correct? I assume it would need to be placed before the catalytic converter (or, in my case, the pre-muffler)?
Chain fence eating turbo
Samples 1000 X's a second and the display will change tenths of an AFR faster than you can see/interpret.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
To circle back on this, I did end up buying the 14point7 iDash. I've written up the installation and use as I wasn't able to find any reviews on it. So far I like it.
14point7 iDash Wideband Controller Todd
'81 SC |
I have 2 MTX's fitted to my V12 and they have worked perfectly for 2 years, the response is very fast. Recently one of the gauges has started acting up and I think one of the sensors is going strange. I've ordered a new one.
For the money I think innovate kit is good. Just make sure you mount your sensor a little way back from the header and in the upper section of the pipe....between 9 and 3 O Clock.
1983 RHD SC 3.0 1994 RHD E31 850 CSi |
Better than Daytona-Sensors WEGO IV?
Better? I'm not sure. It suites my particular needs better. All the information is up on their website - 14point7.com.
It seems to support a lot more inputs, a lot more display options, don't have to install the display, and uses the same Bosch sensor. It's $299 for single sensor and controller, $399 for dual sensors. Todd
'81 SC |
