Advice from auto electrical gurus?
Guys, I have a rear bosch 044 fuel pump wired on its own circuit/relay.
Is it possible to run an electric oil scavenge pump off the same circuit in parallel, temporarily? Max current draw on the oil scavenge pump is 5A.
I just need the oil scavenge pump going so I can drive the car to the auto electrician so he can wire the oil pump on its own circuit.
Advice appreciated!
Old 09-12-2014, 06:24 PM
porwolf's Avatar
I would bypass the fuel pump fuse with a separate in-line fuse so as not to overload the fuel pump fuse.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 09-12-2014, 06:37 PM
ROW '78 911 Targa
timmy2's Avatar
Temporarily Run an in line fuse for the pump off of one of the 3 rear fuses that normally feeds your defroster. Shouldn't need it anytime soon.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-12-2014, 08:30 PM
Thanks guys. I don't have a rear defroster. My car is a turbo cabriolet.
The electric scavenge pump is to pump the oil drain from two turbochargers back into the oil system.
Is there a fuse and power source in the rear panel which gets power when the engine is running, so I can tap the power for the oil scavenge pump from that source?
Or are those rear panel power sources manually activated?
Old 09-12-2014, 08:50 PM
