LinkBack | Thread Tools | Rate Thread |
I'm looking for a Stoddard caliper adapter for early 911 struts...
Does anyone have a set of the caliper adapters made by Stoddard that allows the mounting of 3.5" calipers to 3" bolt-spaced struts on the front of an early 911? Let me know!!! Thanks a lot
i bet a reliable place like black forrest knows a good machine shop that make on for you...it is just a piece of metal with 4 holes...can't imagine it would be too hard
MJ |
The only time I ever saw one of these was in an old Stoddards catalog. It could probably easily made though.
There are at least a couple of other ideas in vogue to put larger front brakes on a narrow (3") eared front strut. One is to slightly modify a Boxter monoblock caliper and the other is to use a BMW Caliper. I understand that there are minor modifications to the parts in question. Good luck, David Duffield |
Don't know about regular 3.5" brakes, but these guys have an adapter for the 3.0" mounting that let you use Big Reds.
http://www.vehiclecraft.com/Brakes/vciweb4.htm Look for VCI 6601
Robert Currently Porsche less (but the wife has 2) |
