Jnikic's Avatar
Reconfiguring 3 piece wheels for widebody
I've been running a set of 18" Jongbloeds on my track car, but the fitment wasn't perfect (I need a large spacer and 100mm studs to make it work on the rear) and I just purchased a race car that came with 17" CCWs.
So I've decided to step down to 17" barrels and would appreciate some insights into the ideal back spacing for a widebody setup ...
I would like to fit a 315mm rear tire (but will likely stick with 295's) and end with a 10" rim width to meet PCA rules.
78 911 Coupe :: E Prepared racecar :: Stock 3.0 :: Steel widebody :: 930 brakes
78 911 Targa RSR backdate :: 3.2L :: 10.5:1 Wossner pistons / Mahle cylinders :: Twin plug crankfire ignition :: 46mm PMO
Old 09-15-2014, 03:56 PM
Bill Verburg's Avatar
The usual fitment if the chassis is SC and the fenders are 930 in back is 11" w/ -8ET
a 10 w/ ET-20.7 will place the outer wheel lip in the same place as the 11 w/ -8ET. There will be a full inch of extra backspace.
Bill Verburg
Old 09-15-2014, 04:14 PM
Jnikic's Avatar
As usual, Bill comes to the rescue - thanks Bill!
What about fronts? I can run 9" there, which I think it ideal ...
Old 09-15-2014, 04:17 PM
the usual 9" front is ET13
Bill Verburg
Old 09-15-2014, 04:36 PM
