Heater duct caps - any DIY solutions?
Looking to cap my heater duct (without removing and installing a block-off plate at this time) - was curious if anybody has found a good solution or a cap (that can be through-bolted to the duct) that will fit it perfectly? And look decent. About 3.25" diameter.
DD summer/winter: 2000 Boxster S DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale) http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story |
Check your local hardware store for rubber plumbing seals. I don't know the exact name but they can be found where the drain pipes are located. A band clamp will hold it in place.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
go to the grocery store and start measuring. I think I used the bottom of a peanut butter jar. just look for something that looks the part
82 SC , 72 914 |
Try universal freeze plug the type with rubberbackside insert turn bolt done.
Yup that's what I've been doing. Measured every cap to jar I have in the house...and whenever I'm out!
disband
beer can bottom with a hose clamp.
it'll make ya get the block off quicker. 8k even post
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I did this with the top of a coke can on my ATC70's DG down pipe when I was 13 years old. It lasted right through someone jackin' it from me more than 10 years later. Hack sawed the end off the muffler, ripped out the guts, and had the raspiest sounding bike on the block.
I used a tuna can, even went all out and painted it black.
But the fiberglass blank plates are pretty cheap and look good. |
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
iv also used a piece of rubber from an old inner tube and a clamp for things like this. zip tie or a cv joint boot clamp would be cleaner
82 SC , 72 914 |
Platinum Member
I seem to remember the top from a can of spray paint fits.
home depot or lowes, plumbing, 2.5" rubber caps, 2.99$ each, just bought 4 of them
McMaster Karr has high temp silicone rubber caps from 1/4" to 4".
I put one on my MFI pre heater tube which I don't use.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Rey....77 930 "the Mistress" |
Information Junky
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
disband
for that i used a rolling rock cap
Mike Valley Grande, AL 1987 911 Targa, White |
Plain exhaust headers? Okay
Factory heat exchangers w/o air flow? No Without air circulating through the heat exchangers, the sheet metal clam shell traps radiated exhaust heat and in effect replicates an oven environment. Is there any advantage in retaining 400ºF+ air in that area? Answer: Nothing I can think of other than prepping a meal of slow-roasted brisket or fish in foil. If the heat exchangers are still in place, suggest restoring the factory air path with the proper 3.5" duct hose. Sherwood |
My engine normally ran on the cooler side even with these hot and humid Alabama summers so the cooling system was in fine working order. Others have done this apparently without negative results though that is not what I experienced!
Daryl G. 1981 911 SC - sold 06/29/12 |
