User
What weight oil are you NE guys running?
I'm doing my first change on my '80 911SC (First change after complete rebuild) and the previous owner ran Castrol GTX 20-50, I believe. But he lived in Southern Georgia... I'm in Pa. Also, anything to look out for, or tips, other than what Wayne outlines in 101 projects?
I'm definitely overthinking the simplest thing that you can perform on this car, but still. Thanks!! Last edited by Jezza; 09-19-2014 at 07:16 AM.. |
I'm in CT - also running 20-50. Then again, the won't see winter driving.
Wayne 1980 911 SC 1960 MGA 1600 |
15W-40b
I am in SE PA. I also run 20/50. I used to run Castrol, but then all these freaks on this board convinced me to use Brad Penn.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Straight shooter
Chevron Delo 400 Multigrade 15W-40. Stored indoors and not run in the winters due to salt/brine.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Eva
Bp 20-50
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Troll Hunter
20/50
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
I'm in central jersey running 20w50 valvoline vr1. Has a good zinc content, and it seems to run better than my older oil. With these motors stay away from low zinc content found in modern oils
1980 Porsche 911SC |
I'm in Canada, no winters but cool seasons.
20/50 and a thermostat on front mounted cooler so that cold oil doesn't blow the heck out of it when I start it cold. ![]() Less smoke than 15/40 and cooler operating temps (never above 180 even in traffic now but saw 210 even with my cooler with 15/40 I have found).
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Im in CC Philly running mobile1 10-30 in my 789SC right now (I think thats what I put in last time). If you want any help with the change or with the car, PM me im always around and right down the street.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
15W/40 Year round in NJ.
Scott 1981 911SC Targa - Platinum Metallic |
BP 20/50 in PA. Don't plan on driving it when there is salt out.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Anyone put in the new 10W-60 from Porsche Classic yet?? I have to admit I am tempted...but at $15.95/L, the temptation only goes so far.
M1 15w/50 from the time they first came out w/ it
prior to that Castrol GTX 20w/50 but my cars aren't driven winters, they are 9 mo cars
15-40 rotella
86 Targa |
Mo money = mo parts
BP 10w/40 Racing - yes, they make it.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Seems the key questions here are 1) do you plan to drive it on cold winter days, and (perhaps more importantly) at what temperature does it sit when not in use?
My thought here is that a "heavy" oil is primarily an issue when the oil itself gets very cold and becomes sludgy, as it would offer limited lubrication. If a car spends the night at 5 degrees farenheit, 20w50 oil would likely be compromised until it warms up. OTOH, if the car spends the night in a 60 degree garage, the engine running with 20w50 oil @ 60 degrees would not be compromised when exposed to 5 degree ambient temperatures and the oil would just get warmer as the car warms up. Even though my daily driver targa lives in a heated garage, it spends its days in an unheated parking lot. Since we get some single digit days during denver's winters, I run a lower weight oil during the winter to assure that it won't be compromised when I start it after its been sitting in the cold unheated garage at work all day. |
User
I went with the 20/50. I travel pretty much all through the winter months and have no desire to drive it in the cold and salt. It sits in a garage, not heated but insulated. So, it never gets horrifically cold in there. Thought you would all enjoy this. I fumbled the drain plug and it went directly into the drain, clogging it and almost instantly overflowed. I jammed my fingers into the pan filled with hot oil as I tried to find the plug. That sucked. ![]()
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Sounds good, you should check out the local PCA. Its a huge chapter and a great way to meet people in the area. A lot of the people seem to have the newer stuff but there is a solid vintage crowd there as well. I am not in fishtown I'm right in CC by city hall. Regards Dave
