Pedal Cluster part ID
Pedal cluster from 1973 911.
![]() I need to order the brass bushing kit, but I wanted to make sure I ordered the the parts shown with arrows as well if they are available. Anyone know part numbers for these? Also, any suggestions on other pieces I should get in addition to the brass bushing kit for a pedal cluster rebuild? |
The nut on your push rod is not available separately. I don't see any reason to replace it. The plastic spacer is probably 911.423.219.03. Usually that doesn't go bad either. I'd replace the rubber pad for the pedal stop and probably the large washer that activates the brake light switch. If the springs have any surface rust pitting, replace them.
JR |
