sugarwood's Avatar
Friend's engine has been in rebuild shop for 2 years. Is this normal?
A friend mentioned this the other day and it seemed crazy to me.
I would not be comfortable having all my engine bits scattered in some shop for that long.
Seems like a great way to get stuff lost or mixed up.
How long is an acceptable time frame for a shop to rebuild your engine?
For the sake of this discussion, let's just talk about a stock rebuild, not a performance track upgrade.
Is there a ballpark confidence interval time frame that most shops fall under?
For example, "80% of rebuilds are completed within 3 to 6 months"
1986 Bosch Icon Wipers coupe.
Old 12-03-2016, 07:50 AM
gshiwota's Avatar
Mine was rebuilt in a week.
Old 12-03-2016, 07:55 AM
ted ted is offline
likes to left foot brake.
ted's Avatar
2 weeks to disassemble and clean.
2 months with parts at a busy machine shop.
(shop should order required bearings and parts during this delay)
3 weeks to build it and reinstall it?
I'd say 3 or 4 months.
Add a few weeks if customer needs to make decisions on replacing found worn items.
2 years is a good time frame for restoring a complete car.
I had a V8 rebuilt that took 6 months, but it was a one man shop and my V8 was number 10 in line when I dropped my mine off to be put in the waiting line.
Old 12-03-2016, 08:04 AM
Registered Minimalist
75 911s's Avatar
Top end or split case? And it all depends on the relationship with the builder. Is this "get to it when you can for a discount" situation? Sounds like it.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-03-2016, 08:09 AM
Troll Hunter
I have a sneaking suspicion where this engine might be. If I'm correct, the shop is somewhat renowned for taking forever on builds and restorations. As a result of recent developments, it might take even longer now.
As you can see from the other responses, the actual work itself on a standard rebuild shouldn't take that much time. It's where your friend stands on the list of the shops' priorities that matters. The shop I'm referring to gets to things as they see fit. It's just the way it is there.
After 2 years, I might just go settle up, take my engine and move on to another shop. 2 years is nuts.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 12-03-2016, 08:17 AM
Slippery Slope Victim
NY65912's Avatar
Wow. 2 weeks IMHO in/out
Mike²
1985 M491
Old 12-03-2016, 08:18 AM
With current machine shops turn around times I would expect it to take 6-8 weeks.
Because of the rise in value of these cars all of the machinist' that are familiar with air cooled engines are currently swamped with work
2 years seems a bit long
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 12-03-2016, 08:53 AM
Two years is criminal.
One year is rediculous.
Six months is way too long.
Anyone that does it for a living should be able to turn around a stock rebuild in less than a month, with several others going at the same time. The only unpredictable time is how long the shop is backed up before they start.
Old 12-03-2016, 08:56 AM
non-whiner
mreid's Avatar
My 930 engine was done in 10 days. Two years is criminal.
"Too much is just enough."
Old 12-03-2016, 09:01 AM
That Guy
Techno Duck's Avatar
Time frame expectations should always be discussed before hand.
I just had a split case done on my 3.2L which was bumped up to 3.4L. Initial estimate was 5-6 weeks. Engine was completed at 7.5 weeks. Everything was handled by the shop i used including removal and install. The crank and rods came back within a week, the heads took about 2.5 weeks. I thought this was pretty reasonable, mind you he had atleast 2 other engine builds being done at the same time. Some minor setbacks regarding compression ratio requiring machining of the pistons added time. If he was 100% focused on my car i think under a month isnt unreasonable.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-03-2016, 09:29 AM
sugarwood's Avatar
Thanks for the perspective. It sounds like a few months is perfectly normal, but once you get over 6 months, you are encroaching into raised eyebrow territory.
Old 12-03-2016, 10:00 AM
sugarwood's Avatar
vs.
I know nothing about rebuilds. What are the main themes involving a machine shop?
When do you need to send stuff out to a machine shop, and when do you not?
For the guys that came in under 2 weeks, did you send anything to a machine shop?
Old 12-03-2016, 10:03 AM
sugarwood's Avatar
This thread has got me thinking.
We try to do small repair jobs at home (Brakes, etc)
I'm thinking small shops are best suited for medium jobs (alignment, suspension, etc)
But, based on your experiences, if one ever needs major work done (tranny rebuild, engine rebuild, etc), does it make more sense taking your car to a major "corporate" type of big racing shop? Sure, I bet they cost a lot more with their larger overhead/staff, but those places may run more efficiently on a schedule (vis a vis 2 bay shops that have stuff lying around that is months or years backlogged) For a major project, is it worth paying more to ensure avoiding a small shop quagmire that can't handle the volume?
Old 12-03-2016, 10:19 AM
There should be plenty of shops around that can get it done in a reasonable time without taking it to a major "corporate" type of business. I don't like those kinds of places in the first place and prefer a place I can talk directly to the person doing the work. The last engine I had done took six weeks total with me taking the engine in in pieces and parts, since I did the disassembly and farmed out work like ceramic & dry film lubricant coatings before taking it in. He should go pick up his stuff and find a better place to finish it. I even shipped a 915 trans from SoCal to Seattle to JW years ago for rebuild. I had it back in about three weeks.
Marv Evans
'69 911E
Old 12-03-2016, 10:44 AM
Originally Posted by sugarwood View Post
?...... Sure, I bet they cost a lot more with their larger overhead/staff, but those places may run more efficiently on a schedule (vis a vis 2 bay shops that have stuff lying around that is months or years backlogged) For a major project, is it worth paying more to ensure avoiding a small shop quagmire that can't handle the volume?
NOTHING should ever sit around in a shop that long, unless the customer can't pay, and even in that case the shop should have sold it for what is owed. Big or small, there is no excuse for running a business like that. I did a split case rebuilt on my engine in less than three months, and I have a full time other business that required my attention 50+ hours a week. That also included heads, crank and rods going to a quality Porsche machine shop, and waiting on several orders of parts from pelican. I would kick my own butt if I was in a business and couldn't have done the job in 3-4 weeks
Old 12-03-2016, 10:59 AM
Crotchety Old Bastard
RarlyL8's Avatar
2 years is not anywhere close to acceptable unless there are circumstances that have not been exposed. You are now into the danger zone of never getting the job done, never getting the engine back, or parts being lost.
Here is the reality for the builds we do in the shop I use:
> 930 engine rebuild is 40hrs shop time plus parts. Deliver engine to us, typical rebuild, no busted parts = 2 weeks with machine work.
> Engine Restoration - full disassemble, rebuild, clean and paint everything, replace all hoses, recondition all worn externals = 3-4 weeks.
> Bring us the car - 6hr shop time engine in/out. Rebuild then back in and tune = time and materials.
None of these scenarios take longer than one month unless the "while you are in there" bug hits or parts get hung up on back order. Key is you don't bring the car or engine until the shop is ready to do the work.
Old 12-03-2016, 11:09 AM
Fleabit peanut monkey
Bob Kontak's Avatar
+1
There is something wrong.
Call the dude with a non-offensive front. Get to the bottom of the delay. Force him to state why two years is "ok".
I sense he knows you are "flexible" and he is leveraging on that.
If you want to expedite, I can call him.
1981 911SC Targa
Old 12-03-2016, 02:16 PM
86 ssinit's Avatar
Sugar I am looking into this now. My Indy shop is great I've had no problems with him. But I've watched him rebuild 2 engines since I've been using him. It takes him at least a year an engine and he tells you that up front. He's got a room for engine rebuilding so nothing gets lost. He does a lot of work and gets to the engines when he can. He sends all parts out that need to be machined. I also have a few race shops near me and have been told anywhere from 2 weeks to 2 months on a rebuild. They all rebuild engines on a regular basis and do there own machine work. All are around the same price. For me it's going to be the race shop I just can't see laying up the car for a year.
If your buddy wasn't told from the beginning how long it could take and is upset with the time he needs to send it somewhere else. The 2 guys at my Indy shop knew what they were getting into and own other cars. Both are very happy with the work done I just can't wait that long.
Here in New York there is not enough business for Porsche engine rebuilding so the smaller shops are not geared up for it.
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 12-03-2016, 03:03 PM
sugarwood's Avatar
I agree to skip the Indy for this one.
If doing something this big, I wouldn't even limit your options to LI.
I'd explore CT & NJ and find the place I feel best about.
A longer tow is a drop in the bucket of the final cost.
Are you rebuilding your blown engine?
Can a cracked case be saved?
What did you conclude about sourcing a replacement engine?
Old 12-03-2016, 04:23 PM
I would have gone and got my engine back after a couple months.. Hope your friend gets it figured out asap at this point since it's been 2 years already!!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 12-03-2016, 04:43 PM
