mycastle's Avatar
Oil Pressure
Looking to understand what "0" should indicate on the gauge.
Have a 78 91SC - with ignition on, but engine off - what should the gauge read?
Pegged low or "0"?
Mine reads pegged low and only comes up when engine is running. starts at 1 at idle but after warm up it bounces around the low peg at idle - gets as high as 3 at redline - hot or cold. wondering if I have a bias issue. Engine rebuilt less than 15K ago with a carrera oil pump installed - has indicated this way since I got the engine which was over 10,000 miles ago.
appreciate your thoughts.
1978 911SC Euro
1970 914 1.7L Sold
1972 914 2.0L Sold
Old 10-07-2014, 08:55 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Seems like the DRUCK sender is being little lazy. Check to insure ground is clean and secure for a proper signal to the Druck Gauge.
'85 Carrera Targa
PCA/POC
Old 10-07-2014, 11:33 PM
