LinkBack | Thread Tools | Rate Thread |
High beams only work if I hold back the stalk. Just Replace stalk ?
I am going to replace the steering wheel bushing (PEL-ML-STR), so I thought to address the high beams while the steering wheel is off.
Low beams work correctly. When I pull the stalk towards me to "flash to pass", the high beams work properly. But, when I push the stalk away from me, the stalk firmly clicks into place, but the lights totally go dark. Not even low beams are on. I'd like to get both done at once. With shipping taking a week, I'd prefer to order the new stalk unless there's a high probability the original is easy to fix. Can my stalk typically be fixed, or should I just order part number 911-613-305-01-M78 for $125 (SWF) and be prepared to replace it? Oh, PO did an H4 upgrade, but I'm not sure if the tech installed relays. Where is the best place to look? If I don't see them, should I just order the Pelican relay kit? JWST-911-HLPR. That has quality relays? The relays can be done indep. of the steering wheel job, but I'll include them in this order. UPDATE: I ended up replacing the turn signal stalk for $125. My brights now can stay on! It took a while, but was doable for the beginner.
There are 3 wire harnesses that feed into the headlight switch. ![]() I wrote them all down, in case someone ever mixes something up. This is from a '86 coupe Turn signal stalk harness White/black -> 56 Grey/black -> 58L (inside) Grey/red -> 58R (inside) Red/white -> 75 Plug Prong harness Grey/black -> 58L (outside) Grey/red -> 58R (outside) Grey solid -> 58 (between 56 & 30) Grey/white -> N White/green -> 57 Black/blue -> 58a Electrical tape wrapped harness Red/white -> 75 Red solid -> 30 Blue/black & Black/blue -> 58a
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 10-25-2014 at 11:33 PM.. |
if you are looking for relays for the headlights, there is a kit here that is fine. JWST-911-HLPR
As for the stalk fix, I think there may be a fix. I say that only because my hi beams turn on when the turn signal returns home - and there is a fix for that. And my stalk is only a few years old. Perhaps the h-beams can be fixed in a similar manner that someone can share / point to.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Regis turd ab user
Disconnect the ground at the battery while fiddling about or you might be buying a new switch.
muck-raker
you can either bend the contacts in the old switch, or buy a new one.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I had a similar problem. My High beams would flick on over bumps. The place where I buy some of my parts told me I had to replace the switch.
On removing the switch and a good look inside. I discovered the contacts could not only be accessed but manipulated to gain the correct clearances. A good inspection and a bit of common sense will save you some $ on this. |
The switch sounds like it fails in two ways. One is with bad contacts. The other is with a failed toggle "clicker" action. My high beam stalk doesn't click. Is that a different issue than the fixable bent contact point issue?
1986 Bosch Icon Wipers coupe. |
I'm just curious. Are you pushing the stock forward for high beam or pulling back expecting it to be like many American cars are?
1984 Carrera 1985 Vanagon Westfalia 2009 Audi A3 2015 VW Jetta 2016 Sprinter |
Regis turd ab user
Read the attached link, it should be clear.
It is a mechanical switch that makes electrical contact, so if it is not right mechanically then it can't function, and yes the clicks are/were related to proper function. If you do get it to work it might not feel or sound as it did previously. |
Heck, I’m only 5 not 71!
If a relay kit was installed with the H4's then it would most likely be in the frunk right near fuse 1 on the fuse panel since the high beam low beams are on fuses 5 thru 8. When I did mine I used the Bosch round relay connectors and have them hanging right next to the cover near fuse 1. They can either sit right behind the carpet or be pulled out on top of the carpet.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Here is a clarification. When I pull the stalk towards me to "flash to pass", the high beams work properly.
Clean/adjust the contacts. A little fine sandpaper will remove any corrosion and they will be like new.
use this drawing because I did not show were I cut the circuit. this one has the cuts.
I'll hold of on buying a new stalk. When I do the bushing, I'll try to remove the stalk and clean the contacts.
But, if the shop incorrectly wired the high beams, I'll probably have to take it to a pro. I doubt I can debug and correct a professionals work. That wiring diagram is beyond my pay grade. If there were pictures and directions, I could follow that. This gives me pause to attempt the relay project. I've only read how simple it is, but that diagram is Greek to me.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 10-07-2014 at 09:03 AM.. |
1. Unplug battery 2. Unplug wires from appropriate spot on fuse panel 3. Plug in Relay 4. Plug in battery Vast majority of the time will be spent fishing the relay wires behind the fuse panel for a clean install.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Carmagic.us
I have the same issue with the Hi-beam going on when the turning signal switch returns. Something to fix.
However, here is a picture how I did the H4 relays install. ![]() Here is the complete install, with the information what parts are needed. Engelbert's Garage - Cars - Autocross - Car Racing and Porsches Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
I'd like to examine the cross section of the high and low beam contacts, like in the photos.
Do I just remove each screw on both sides? Then what? Pull the casing apart? Strange fastener. I wonder how the screw holds the top and bottom casing together.
I looked for relays, and didn't see anything obvious.
I see some wiring tucked underneath the large gas tank tube, but do not know it that's all stock. My (+) battery terminal has 3 main connected to it. 1 thick cable that probably goes to the starter. 1 thin black cable. 1 harness of smaller red cables. Are all 3 part of the OEM configuration? Or could one of these be a direct power source for relay enabled headlights ?
