89 Carrera Rear Sway Bar mount thread repair
One of the bolts like the one in this pic that fastens the sway bushing housing/cap that holds to the coachwork will not torque completely and after a few hundred miles starts to get loose. What is the best way to fix the thread problem?
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion Last edited by bcheney; 10-07-2014 at 08:35 AM.. |
89 Carrera rear sway bar
Any feedback....run a tap down into the threads??
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion |
Member 911 Anonymous
I placed a SS lock nut there. PO stripped the nut. Yes, so the OEM welded nut and my lock nut fix. It is pretty secure now.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
rear sway bar
Draco...just so I understand...you placed a lock nut on top of the welded in nut which is inside the housing and just ran your bold up through both of them?
Lock Nut for extra measure.
