Do I need a brake tool?
If I change the rear brake pads on an 86 911, do I need one of those tools to twist the rear caliper pistons back in? Or, can they be pressed in like the front caliper pistons?
Bonus question:
What are the recommended brake pads for routine use? (meaning, I'm not racing the car and I'm on a budget)
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 06-23-2016, 08:43 PM
Wyvern's Avatar
No special tool .
Your system uses a drum inside the disc hub so it is 2 separate systems. You only need the twist / push tools when the e brake uses the disc caliper.
For pads good ol OEM if you can get a good deal (shop around a bit)
Our host here has a range from OEM to aftermarket (more or less same compound as OEM) or go the other way and track / Auto -x conmpound
Brian
Old 06-23-2016, 09:01 PM
I heard once that racing pads are sluggish unless you get them really hot. Does that sound accurate?
Old 06-23-2016, 09:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Porterfields R4S, plug and play, no bedding in required
'85 Carrera Targa
PCA/POC
Old 06-23-2016, 10:14 PM
gtc gtc is offline
abides.
gtc's Avatar
If you're just replacing the rear pads, you should try to match the fronts. Not a good idea to mix pads, unless you're doing it deliberately to adjust brake bias.
I've always used the cheap pads that Pelican sells... generally Mintex. Work fine for me. They last a long time and still stop just fine, so I haven't seen any reason to go to a fancy race pad.
Pro-tip: If you don't have your brake pad wear sensors hooked up, SC brake pads are the same size as the Carrera pads, but SC pads are generally cheaper.
Graham
1984 Carrera Targa
Old 06-24-2016, 09:37 AM
Use the old pads and press against them.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-24-2016, 10:23 AM
That's a good tip gtc!
Old 06-24-2016, 01:02 PM
Roger at Pelican Parts's Avatar
@Pstallo, for more information, I'd recommend consulting our tech articles: Porsche 911 (1965-1989) Technical Articles - Pelican Parts
Old 06-24-2016, 03:45 PM
sugarwood's Avatar
You just need basic Textar pads.
Yea, you just press the old pad back in with ViceGrips.
How much of a budget are you on?
Used Textar Brake Pads (75% left) 84-89 Carrera 3.2
1986 Bosch Icon Wipers coupe.
Old 06-24-2016, 06:59 PM
