super80's Avatar
TRE Backdate '65-73 Hood and Hood Crest ?
I am currently fitting the TRE Backdate '65-73 Hood on my '77, and was wondering if any of you who have used this hood on your backdate project also installed a hood crest/emblem?
If so, can you show me some photos of the underside of the hood after you installed the crest? It definitely requires some cutting on the underside in order to be able to access the speed nuts for securing the crest. I am unsure as to how much/where to cut. The crest will be a little too close to where the hood latch bolt recesses are on this particular hood.
Help....
Vic
What the FUCH ?
1977 Porsche 911S 3.2L Frankenstein
Old 10-12-2014, 10:11 AM
non-whiner
mreid's Avatar
Why not remove the studs and use emblem tape to attach the crest?
"Too much is just enough."
Old 10-12-2014, 10:15 AM
super80's Avatar
I already measured and drilled the two holes for the emblem pin.
Vic
What the FUCH ?
Old 10-12-2014, 10:27 AM
non-whiner
mreid's Avatar
The tape and crest will cover the holes and you will avoid additional work on the back of the hood.
Old 10-12-2014, 10:31 AM
be here now
R K T's Avatar
I just used a crest sticker.....looks good and saves weight! :-)
Rob....
Old 10-12-2014, 11:41 AM
Tags
backdate , crest , hood , tre
