Case stud oil leak
I have an original 6 engine in my 914/6 conversion car. I have an oil leak at the stud circled in the pic below. I have tried to torque the nut down onto this stud without success. I then double nutted the stud to see if maybe the stud and become loose. I was able to turn the stud in a bit but it would snug up correctly. When I removed the double nuts and placed a washer and nut back on to torque to value it won't snug up. Instead, as I torque the nut...the stud begins to turn out. I have a bad feeling about this....Please chime in with your wisdom.
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion Last edited by bcheney; 10-12-2014 at 12:02 PM.. |
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion Last edited by bcheney; 10-12-2014 at 12:09 PM.. |
here is the pic
Here is the pic
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion |
Case is magnisium and the studs are pulling..even on the oil panel.
Bruce |
Pic
Trying again to post a pic... Not sure why it didn't post
Smear silicon on and around it. Leave it until you are ready to split the case, and stop effing with it.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Fleabit peanut monkey
That's odd. I see a reference to your upload in your quote - but no pic.
Is it a through bolt? There are head studs and through bolts in the case. Through bolts have o-rings and convex washers, if I remember correctly. They are replaceable if they have cooties.
1981 911SC Targa |
Don't use the message at the bottom, use "post reply"for pictures. It's in the Orange block
Bruce |
Leak
Undocumented User
I think your picture is leaking.
Yes is a tragedy around here...
Reiver
Lol, yes it is.
If it's the one stud and isn't affecting anything just put more oil in and go until you decide to break it open.
De Oppresso Liber Strength and Honor 5th Legion |
Vintage Owner
Mine did the same thing years ago. That stud holds the webbing under the intermediate shaft bearing, and can pull just like others if it wasn't timeserted or otherwise strengthened at it's attachment point in the case. In my engine, they tapped the hole for a threaded bolt with an O ring. It held fine for many years until I had Henry at Supertec rebuild the engine with Casesavers throughout.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Oil Leak
Well I am not sure what the heck went wrong with the forum on my computer...Finally was able to post the pic.
