moneymanager's Avatar
Scraping noise from rear suspension; inner banana arm bushings?
I have an awful scraping sort of sound coming out of the rear suspension that so far has defied detection. The sound is what you might imagine the heat exchangers might sound like if they were somehow scraping on the body while the car was being driven.
I hear the sound at slow speeds in left hand turns, and occasionally when getting in and out of the car and loading the suspension. We have changed a few parts and tested after removing others. For example the car has been driven without sway bars, and the spring plate bushings have been replaced. The shocks are new, the motor mounts seem fine.
A current candidate for the noise is the inner banana arms bushings which have been in this 1974 car for forty years. Wonder if anyone who has suffered an unpleasant metal-on-metal scraping sound at the rear of their earlier car has replaced these bushings and found relief? More generally, has anyone suffered such a sound and found the cause?
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 10-16-2014, 08:38 PM
Max Sluiter
Flieger's Avatar
dust covers on the dampers?
Old 10-16-2014, 09:57 PM
Max, many thanks. I have checked the dampers at the bottom but not at the top. I'll look. The noise I have sounds like it could be made by the covers hitting something.
jhtaylor
santa barbara
Old 10-17-2014, 11:25 AM
have someone bounce the rear end while looking for the noise. i would say the shock covers too but you said they are new
Old 10-17-2014, 02:05 PM
Can I ask what part is the shock cover. One of mine is creaking and I can't see what part is rubbing on what. Green Bilsteins.
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 10-17-2014, 04:15 PM
When you look at the shock you are looking at two tubes, one of which slides inside the other. The bigger one is the cover.
jhtaylor
santa barbara
Old 10-17-2014, 04:38 PM
That's kind of what I thought. You think the scraping comes form the two tubes rubbing together? Mine seem concentric with about 1/8" clearance all around. Still it is creaking like an old mattress. I am thinking internal issue.
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 10-17-2014, 04:55 PM
Maybe, or one of the tubes is touching the body somewhere as it moves.
jhtaylor
santa barbara
Old 10-17-2014, 05:06 PM
