-   -   How do I access 27mm nut when removing steering wheel ? (http://forums.pelicanparts.com/porsche-911-technical-forum/834065-how-do-i-access-27mm-nut-when-removing-steering-wheel.html)
T77911S 01-06-2015 07:24 AM
i HAD to see why there were 4 pages on removing a steering wheel nut.
i wish i had those 15 minutes back.
why couldnt that plate come off?
there was a thread on removing the nut on the rear axle. that one was very long too.
911pcars 01-06-2015 09:03 AM
Porsche nuts. There is no substitute.
You can take that several ways.
Sherwood
T77911S 01-06-2015 09:29 AM
Sherwood
ah. you too have been sucked into the vast hole of darkness.
Quicksilver 01-06-2015 10:15 AM
If you see a socket with a matte surface it is almost certainly an impact socket.
Normal sockets have a polished plated surface. Really cheap sockets are also apt to have thicker walls. Craftsman, Snapon, Mac, Proto, ... If you recognize the name it will be thin walled with good steel.
As far as the using a "regular socket" on an impact wrench. You don't to it because they can break. But on a one off job like this, turn the air down and try it.
If it breaks then you go get another socket, a breaker bar, and a buddy to hold the wheel. (Or try the buddy method first with...)
pmax 12-07-2017 02:44 AM
Originally Posted by sugarwood (Post 8427153)
LOL, wasn't that simple.
My 27mm HF deep socket was too big.
Then I ordered a different 27mm short socket was also too big.
I borrowed a neighbor's 27mm, but that also didn't fit.
When everyone's saying "Just use 27mm", you start to think you're doing something wrong. But as 911pcars alluded to, 27mm sockets come in all shapes and sizes.
In the end, I ended up using an SAE 1 1/16" socket was in my Craftsman set the entire time!
Learning. It happens.
Where are the pics and vid of this ???!!!
LEAKYSEALS951 12-07-2017 03:23 AM
Originally Posted by KTL (Post 8307128)
Yep short non-impact socket is the key. And don't pay extra for a 27mm because it's metric. Get an SAE/English size socket. 1-1/16 fits just fine.
So post #19 made on the first page in 10/14 using available sockets would have worked if tried.
cabmandone 12-07-2017 04:53 AM
Originally Posted by Jack Stands (Post 8306429)
Don't use a deep well socket, just a normal sized one and it should fit.
^^^ what he said!
I never use a deep well socket.
lpsalsaman 12-07-2017 05:18 AM
You got to love this forum! This thread is funny as hell, but within there are good suggestions from everyone and some crazy stuff from others. When I removed my original steering wheel, I had no issues at all. I wanted a deep socket 27mm but at the time had a regular size 27mm socket, got an extension and got the wheel out. Put the new sleeve for the wobble and installed the Momo steering wheel with the extension. I think I was done in less than half an hour. Anyway this is gold! :D
proporsche 12-07-2017 08:47 AM
did i see Porsche nuts
i have one at home ;-)
ivan
http://img.pccreation.net/photos/201712071746348373.JPG
NYNick 12-07-2017 09:40 AM
Leave it to Max to revive a thread just to bust somebody's balls.
McLaren-TAG 12-07-2017 09:59 AM
I'm trying to remove the ashtray so I can get at the steering wheel nut, can anyone help?
proporsche 12-07-2017 10:03 AM
mc...http://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gif
stevej37 12-07-2017 11:07 AM
with the right amount of universal joint sockets...it can be done. :)
boyt911sc 12-07-2017 11:10 AM
What happens to common sense?
This forum has been a great help to many of us DIY’ers. Unfortunately, it has also made some people to lose their common sense!!!!! Sugarwood insisted using the wrong thick wall 27-mm socket but I had successfully used a similar thick wall 27-mm socket from my impact set for removing the steering wheels of SC’s and Carrera 3.2’s gazilion times before.
You could use a thin or thick wall socket, 6-Point or 12- point socket as long as it clears the opening. The thick wall 6-point 27-mm socket shown in my picture was taken from a Sears Craftsman impact socket set with an OD of 38.2 mm. See pictures below:
http://forums.pelicanparts.com/uploa...1512672939.jpg
The first thing that should had come up to OP’s mind was why were people able to use a 27-mm sockets and mine did not work? What is difference between my 27-mm socket and theirs? What is the largest OD of the socket I could use? All these simple questions could be readily thought by experienced people or have good imaginations. But some might think these as rocket science (?). I believe common sense will be more than sufficient to over come such obstacle. My two cents.
Tony
NYNick 12-07-2017 12:56 PM
Guys, the thread is two years old. Pmax is justing bustin'...
pmax 12-07-2017 03:07 PM
^^^ an attempt, my last I promise, to show the guy that by his own standards below, the lack of pictures of how he solved this is totally unacceptable.
http://forums.pelicanparts.com/porsche-911-technical-forum/979438-my-vintage-911-handles-like-dump-truck-compared-my-modern-daily-driver-17.html
Sugar, would you agree or is this a case where mere words would suffice ?
NY65912 12-07-2017 03:15 PM
I like the pics of the sideways deep impact socket. Perhaps it was just ignorance, not knowing all that much about automotive tools. Glad the job got done. Now I'll go rest.
mrm930 12-07-2017 03:39 PM
four freakin pages on this thread for how to insert a socket on a nut -----Unbelievable!
sky1jord 12-07-2017 04:09 PM
Almost as Unbelievable as criticizing a thread that's nearly 3 years old
McLaren-TAG 12-07-2017 04:46 PM
It's not criticizing! It's observational sarcasm, Jerry Seinfeld has a few hundred Porsche cars in climate controlled warehouses because of the art form. I say get in on the sense of humor action boy, it'll make your life more enjoyable.
