-   -   How do I access 27mm nut when removing steering wheel ? (http://forums.pelicanparts.com/porsche-911-technical-forum/834065-how-do-i-access-27mm-nut-when-removing-steering-wheel.html)
sugarwood 10-14-2014 02:49 PM
I've read many links on this topic, and they all say the same thing:
1) Remove horn pad. Then unclip wire.
2) Remove 27mm nut
3) Remove circlip.
4) Mark steering wheel
5) Remove
I removed the horn pad, but I'm stuck on step #2. The 27mm nut is deep in a recessed cavity. My 27mm socket won't fit inside the cavity. Even if it did, it would not seat flush onto the nut, b/c the nut is not directly behind the opening. Can someone please tell me what I am overlooking?
http://i57.tinypic.com/69e4p0.jpg
Reiver 10-14-2014 02:51 PM
You don't have an extension?
I put the nut on a 6 in extension then attach to air wrench..zip zip....off.
Yahow lam 10-14-2014 02:59 PM
Go to Sears buy their 27mm socket it will go right in with no problem.
Reiver 10-14-2014 03:15 PM
Or a snap on, they are thin walled and strong.
Sorry, missed the real issue.
sugarwood 10-14-2014 04:20 PM
That's too bad none of the 911 wheel removal write ups ever mention needing a thin walled 27mm.
I'll look around for one.
While we're discussing "minor" details, 27mm with a straight extension would be totally blocked by the plate above the cavity opening.
The nut is significantly offset from the opening, and is partially blocked by the plate.
I'm assuming this also requires using a wobble extension or u-joint as well?
Cattler 10-14-2014 05:00 PM
I bought my socket at Lowe's (Kobalt brand). The 6" 1/2" drive straight extension will fit--it might be at a slight angle, but it'll go in. The socket does precisely fit into that half-moon hole. Just did this (again) over the weekend.
sky1jord 10-14-2014 06:29 PM
Beware of overthinking
You are facing the exact FALSE conundrum that I faced when looking at this. As Reiver and Cattler pointed out, there's plenty of room in there for even a standard 27 mm socket when it's mounted on an extension.
Think in three dimensions, you're only thinking in two.
sugarwood 10-14-2014 07:21 PM
I have no idea what you're trying to say.
My 27mm socket has absolutely no possible way to pass the plane of the opening, so adding an extension behind the socket is irrelevant.
Photos to make this more clear:
http://i61.tinypic.com/29z249f.jpg
And here is the offset which will probably require a wobble or swivel u-joint extension
Straight extension bar is risking stripping the nut b/c the socket will only be partially seated.
http://i62.tinypic.com/14dhrpt.jpg
Pazuzu 10-14-2014 07:32 PM
Get yourself a basic cheap 27mm short socket, it's the only thing you'll use it for, so it can be the local harbor freight special, doesn't need to be quality. !/2 inch drive, and a 6 inch extension.
The long thick impact socket is your problem.
Jack Stands 10-14-2014 07:32 PM
Don't use a deep well socket, just a normal sized one and it should fit.
Pazuzu 10-14-2014 07:35 PM
Or dump a buttload of money on one of these:
27mm Oil Socket - Way Motor Works
27mm ultra shorty socket, 3/8 drive so the extension will fit just fine.
Pazuzu 10-14-2014 07:39 PM
Also, order yourself a Momo L231 hub adapter and any Momo steering wheel and never have this problem again ;)
dicklague 10-14-2014 08:46 PM
your socxket is and HFT Pittsburgh deep impact socket.
You need something like this:
http://forums.pelicanparts.com/uploa...1413348387.jpg
GH85Carrera 10-15-2014 04:38 AM
This. A cheap 27mm short socket is all you need.
That is the same problem with the pulley on the alternator. A long socket will not work.
TheSt|G 10-15-2014 05:03 AM
What's with the impact socket?
+1 on getting a Momo while you are in there. :D
sky1jord 10-15-2014 06:53 AM
Originally Posted by pazuzu (Post 8306428)
get yourself a basic cheap 27mm short socket, it's the only thing you'll use it for, so it can be the local harbor freight special, doesn't need to be quality. !/2 inch drive, and a 6 inch extension.
+1
sugarwood 10-15-2014 08:02 AM
The local harbor freight special is actually what I am using. I will look again for a short socket to put in sideways.
sugarwood 10-15-2014 08:04 AM
If you're lucky enough to have a toolkit, it comes with the right tool for the alternator fan nut...
KTL 10-15-2014 08:52 AM
Yep short non-impact socket is the key. And don't pay extra for a 27mm because it's metric. Get an SAE/English size socket. 1-1/16 fits just fine.
dicklague 10-15-2014 02:26 PM
that is what I said....HFT Harbor Freight tools
sugarwood 10-15-2014 06:34 PM
I've been told to never use a non-impact socket with an impact wrench.
Since none of the wheel removal write up mention needing a special socket for this job,
For future readers who are bound to hit the same roadblock,
I'll post what I found for a 27mm shallow impact specialty socket here.
EDIT: Don't get the link above. Apparently, you can only use 12-point
Arne2 10-15-2014 06:40 PM
I was told years ago to never use an impact wrench on any steering column nut. I always just do it with a ½" ratchet, or breaker bar if it's really tight. No way you should need an impact for that.
sugarwood 10-15-2014 06:48 PM
Unfortunately, I don't have a helper to hold the wheel steady.
I really don't want to order "The Club", either.
I will give it a try this weekend, when the 27mm socket arrives.
Derek911 10-15-2014 07:02 PM
[QUOTE=sugarwood;8308109]I've been told to never use a non-impact socket with an impact wrench.
You are not removing rusted exhaust nuts from a Chevy pickup, you are just using the impact tool to break the tension/torque of the nut really quick.:eek: You are correct that regular sockets can't take the rapid torque, but we are talking a steering wheel nut.
OldSpool87 10-16-2014 04:27 AM
Sugarwood- I removed mine the first time without the aid of a club or other's assistance. If you are mindful not to use the steering wheel lock as your counter to the force of the wrench it should work ok. There is a specific torque spec for reinstall (40 lbs I believe). Keep the nut a few threads on while you pull off the wheel. This averts you from customizing your face. Pack the socket with paper towel with a wad of blue painter's tape at the end. It makes the nut stick where you want it for reinstall instead of dropping out into the abyss.
Good luck
Will
GH85Carrera 10-16-2014 05:09 AM
I have to add one other comment.
Don't use a impact wrench on the steering wheel nut. It simply is not necessary. The nut is not on that tight, it is not a lug nut. Use a standard 1/2 "breaker bar" to take it off. PUSH DOWN on the wrench and hold the steering wheel with your other hand. Do not pull the wrench up toward the windshield, it is too easy to smack the windshield.
I have taken my steering wheel off several times. It is very easy to do. No impact wrench needed.
rothaus 10-16-2014 08:22 AM
You need a short 12 point socket with 1/2" drive, the 6 point don't work, because of the wall thickness, regardless metric or standard.
Like this one
27mm
http://images.lowes.com/product/conv...98852980lg.jpg
Cheers
Engelbert
SilberUrS6 10-16-2014 09:16 AM
Good luck
Will
Yup, this is great advice. When I changed my wheel (the same kind you have), I used my 27mm deep socket and an extension. I used a breaker bar and rotated the bar so that I was pulling down on it to loosen the nut. I also used a 2x4 section with a towel over the end to brace the wheel so that I wasn't turning against the lock. I had to cut the 2x4 to length, but now I have a piece of wood in my tool kit called "911 steering wheel removal brace" :)
I didn't have any trouble retaining the nut, so I don't have any advice on making sure the nut doesn't go anywhere, LOL. I did make sure to loosen the wheel from the splines with the nut still threaded on. I have seen what happens to folks who pull and get a face full of steering wheel. :( Luckily, mine wiggled off pretty easily. I also put anti-seize on the splines and threads so that if I ever have to take off my wheel, I can do it without having to think about it much. :)
porschemike 10-16-2014 02:19 PM
Like this one
27mm
Cheers
Engelbert
I installed our host's wheel bushing replacement a few weeks ago. I bought this exact Kobalt socket at Lowes and it worked great with a short extension and u-joint. The socket's walls fit the narrow hole exposing the wheel nut. I tried an impact socket first, but its OD was too large to fit through the hole.
I torqued it to 50 ft lbs, per Mitch Leland/Pelican's instructions.
sugarwood 10-16-2014 04:37 PM
Ok, I'm 0 for 2.
Looks like I'm gonna build up a small 27mm socket collection...
I do not live near a Lowes, so I'm back to square one.
Anyone know where I can order a 12-point 27mm short socket ?
RD911T 10-16-2014 05:35 PM
I found one pretty quickly on AmazonPrime. 9.99 shipped
Derek911 10-16-2014 06:31 PM
You know you can actually "control" an impact wrench. People act like impact wrenches are some kind of crude uncontrollable device that will ruin everything it is used on. I would not tighten a steering wheel with an impact wrench, that is a completely different operation, but using an impact wrench to hit the nut once or twice to break the tension does no damage. Some people would not use air tools on the car at all... To each his own...
88911coupe 10-16-2014 07:02 PM
Will is dead on with his suggestion, I used some tape to hold the nut steady to get it threaded back on the steering column...be careful, you do not want to cross thread this. When I was re doing my steering wheel I got pretty good at getting it back on so long as the nut was snug inside the socket. BTW, really don't need an impact wrench...I just got a good sized socket wrench and held the wheel steady.
rothaus 10-17-2014 04:13 AM
Originally Posted by sugarwood (Post 8309650)
Ok, I'm 0 for 2.
Sorry, forgot to add that I use one of these extensions with the wobble drive, where the socket can move a little, so I don't need the u-joint.
Hope this helps SmileWavy
Cheers
Engelbert
sky1jord 10-17-2014 08:46 AM
Ok, I'm 0 for 2.
Got an ACE hardware nearby? They stock Craftsman now.
agfours 10-17-2014 11:09 AM
+1 Craftsman socket fits. Just did this recently and ran into the same problems you did with the HF hardened deep socket.
Followed all the suggested tips here and worked great... (blue tape between socket and nut on reinstall, do not force against the steering wheel locking mech - turn key in ignition for freewheeling, create a brace against the floor of the car with wood or brute strength resistance,...oh yeah, and replace with MOMO. :) )
sugarwood 10-17-2014 08:21 PM
The 2nd socket was also too large.
While it looked like it would fit around the nut itself, this one also doesn't fit inside the tiny cavity
I'll order this one next.
http://i60.tinypic.com/907o09.jpg
emac 10-17-2014 08:38 PM
Am I just plain stupid or is it a major issue to just remove the three nuts holding the plate that is blocking the socket? No impact needed, hold the wheel between your legs turn left to remove the nut, remove the wheel and believe it or not your done. I can remove my wheel in no less then five minutes. This thread just makes no sense to me. Sorry for being blunt but your not removing the engine.
Ernie 81 sc
I'm ready for the flames!
sugarwood 10-17-2014 08:48 PM
Are you saying you remove the plate?
That's strange, b/c the numerous how-to wheel removal sources I read prior to starting, not one mentioned anything about dismantling the plate.
Besides, those tiny bolts look like they'd need their own specialized ultra thin wall sockets to gain access.
No way a standard socket slides into that tiny gap.
I prefer stick to the standard method of removal, before causing more potential problems.
Unfortunately, it takes a very specific socket.
emac 10-17-2014 09:01 PM
I might be looking at your photo wrong but I would insert the socket the right way
I have a 81 sc and do not have the plate seen in your photos but I have pulled my wheel more times then I can count. Off and on in no longer then five minutes, by that I mean just yanking the wheel
Ernie
