Exhaust stud remova.\drilll tool
Hi,
Does anyone have exhaust stud removal\drill tool that I can buy\borrow?
1976 911 2.7L
Thank you.
p.s. stomski tool is 299 plus 50 shipping to Toronto.
I'm trying to find cheaper alternative for one time use tool.
1974 911 coupe 4 speed
Old 12-01-2017, 09:59 AM
T77911S's Avatar
when you need it you need it.
buy it, use it then sell it. rent it out here.
I would probably make sure all the other studs are good first.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-01-2017, 10:06 AM
theiceman's Avatar
Originally Posted by kavadarci View Post
Hi,
1976 911 2.7L
Thank you.
how many of them did you break ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 12-01-2017, 11:48 AM
theiceman's Avatar
id probably just build something out of an old flange and some stock steel / copper pipe that fits inside the flange hole.
Old 12-01-2017, 11:50 AM
Fleabit peanut monkey
Bob Kontak's Avatar
The bummer is if you want it to be fool proof, depending on your skill set, the machined tool is a better bet.
Would be kind of cool if we set up some kind of rental/loaner tool "team" here.
1981 911SC Targa
Old 12-01-2017, 12:00 PM
9 (I think it's a record)
i pulled two out with stud remover but 7 are still there.
Old 12-01-2017, 12:25 PM
If both studs are broken on the same port, there's nothing to attach the tool with. One stud would have to be hand drilled dead nuts to align the tool for the other stud.
With the myriad threads detailing proper exhaust nut removal without breaking studs, how did this happen?
206 637 4071
Old 12-01-2017, 01:32 PM
c2kid's Avatar
simple trick
i've done them with my tool (homemade, with correct sized discs for port size) with both studs broken with a clamp setup from the stud on the next port. just a bar with correctly spaced pin on one end and hole in the other. washers for spacers to lift the bar on the holding side. the disc on the tool keeps it in place. good bits and an air drill make it go smoother as well. cheers, geoff
Old 12-01-2017, 02:06 PM
Any visuals?
Old 12-01-2017, 02:25 PM
I've read watched everything there is to it.
I followed all the instructions, the two that came out came out with the studs.
Those two were "solid" studs the rest were thinned out in the middle and tiny pressure broke them.
One two I actually attached stud removal tool after they broke off, heated the area around to expand the magnesium (not even mentioning the days of soaking in multiple rust blaster oil), and then the stud broke off again.
It is insane.
M
Old 12-01-2017, 02:28 PM
If I ever get one of these jobs again, I am taking an Oxy Acetylene torch to it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-01-2017, 03:07 PM
The Dude abides...
bigel's Avatar
How much would it cost to take it to a machinist? I had the very same problem on three studs and a machinist friend ground the broken studs off at the head and drilled the studs with ever larger diameter bits. One of the studs backed out during drilling (left handed bit) and the others he continued to use larger and larger bits until only the thread remained in the bore. He then was able to use a pick and pull the thread out like a wire.
This may not be cost prohibitive and would likely be a bit quicker than coming up with a homemade fix.
My 2 cents...
'03 Carrera 4S
Old 12-02-2017, 04:50 AM
The 9 Store
If the engine is getting rebuilt, have the machine shop take care of it all. don't make the problem worse buy mucking up the treads.
All used parts sold as is.
Old 12-02-2017, 05:03 AM
I built an EDM machine because I got sick of screwing around with this sort of issue.
Old 12-02-2017, 05:53 AM
sugarwood's Avatar
If you buy the tool, you are supporting the indep. vendors who make owning these cars still possible after 30+ years.
Consider it an investment in the vintage Porsche community, and an incentive for people to keep innovating, making ownership and preservation possible.
1986 Bosch Icon Wipers coupe.
Old 12-02-2017, 06:15 AM
Sell it afterwards for $200.
Old 12-02-2017, 06:46 AM
Almost Banned Once
sc_rufctr's Avatar
Hooly Dooly... Way to go. Any more info on how you built that?
- Peter
Old 12-02-2017, 07:19 AM
Registered Minimalist
75 911s's Avatar
EDM as in Electronic Dance Machine? And ...is it in your car? :-D How quickly does it remove the exhaust studs?
:-P
So Kavadarci, I went through this, albeit with only 3 broken studs. In your case, I would drop the engine and consider a top end. Whether you decide to do the top end, It's a great opportunity to address the myriad leaks and fix the studs right.
So you could reseal, check the tensioners, fix all the leaky oil lines, triangle of death etc while you have it on a stand. Trying to do the studs upside down and under the car, you really risk ruining the heads if you drill them out wrong.
If you're hard headed, buy the Stomski kit (I found one used for 100) they do come up if you're patient. You can still drill one side of one exhaust out very carefully and then use the kit to do the other side. That way at least one side is perfect.
Cut the stud off flat with a dremel, center punch it for a drill guide. Drill the center out (with good high quality NEW bits) Once you have a hole, you might be able to use an easy out reverse bit. Careful if you move up in drill bit size you risk breaking the drill bit off inside the stud.
Use a new stud to mark your drill bit so you don't drill too far into the head. go slow. When you get one side out, put the stomski kit on and do the other stud.
Again, with 12 broken studs, Grab a friend and wayne's book. Drop the engine, separate the trans, put it on a stand, flip it over and do it right. Those studs are a total @$%*(%!@!~
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-02-2017, 07:39 AM
Vintage Owner
Jack Stands's Avatar
Stomski also sells a drill guide for $18 that centers the drill if you need to drill out a stud. As long as even a small amount of the stud is protruding, it should work great.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 12-02-2017, 08:00 AM
High Life's Avatar
What a nightmare. I'm just dreading the day I have to go through this..
Never heard of EDM before this post.. Wow.. Porsche 911 EDM Broken Bolt and Stud Removal | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Seems like a last resort.
1981 911SC
Old 12-02-2017, 09:15 AM
