You may well have hit on the kindling answer. (Yes... car in my possession only.) It's very possible that resistor was out for a while. I simply can't remember but that would seem to be the ONLY way for foot rest wood to get in there. Damm fine thinking Will. Am calling that mystery solved. |
A slow, "low velocity", leak via the Schrader valve would not "carry" the "clear to see" refrigeration oil which would otherwise indicate a leak.
If I remember correctly some of the early pictures did show evidence of abuse around the mounting screw holes for the inlet/resistor duct. |
Nice write-up, Karl, and really a fine and determined effort to stay the course with this despite the many battles between the mobile a/c experienced and the mobile a/c inexperienced that stunk up your previous threads (which I acknowledge having a MAJOR role in).
This is a great summary and photo-documentation of your earlier threads. I am very glad you now have excellent performance from your a/c. I suggest your next thread should be 'A Summary or Guide to the Summary of "My a/c Burns me up"'.
Great job, Dave |
Good to see your back Karl!
I agree,a great guide and I would go a step further and recommend a more direct thread title like aircooled a/c .The bible:) Also, this is one of the most important things learned from this was to USE the thermostat control, before, like probably most people when it got too cold I would turn the blower down rather than turn the thermostat up. When the air starts coming out below 40, just turn the temp up a bit , works perfectly without freezing the evap. Cheers, |
With a fully functional system provided the T-stat is properly, correctly, calibrated and installled correctly the evaporator should never freeze up. |
I'm glad you finally got the results you wanted, Karl. Now, of course that summer is coming to an end, I finally got the last parts to finish rebuilding my system.
Temps never got over 85 all summer in Rockwall. Word to your Mother as Vanilla Ice says. (Am I dating myself?) |
Nice work. Good write up.
Glad to have been able contribute in a (hopefully) positive way. |
Good time for 29 degree "gas story." If you will, a detailed song & dance on your method would be excellent. Am curious as to what special treatments you might be managing. Obviously you're doing more than a few things right. |
This is a really great write-up! Congratulations on seeing it through and taking the time to detail everything!
Slightly off-topic - I found the single best thing I did (quick/cheap/effective) was to line the frunk with sheet rubber draught excluder. Just cut to fit and not even glued in, so I can check for condensation underneath it. Amazing how much outside air gets through the dash and fights with the cold AC air. You wont believe the difference! http://forums.pelicanparts.com/uploa...1413910234.jpg http://forums.pelicanparts.com/uploa...1413910142.jpg |
Bob, one of the few times when you will NOT hear me squalk about the heat is when I am cruising in my icy, pimp-hand machine! And you are confused there, buddy boy - you meant to say that it never got BELOW 85 in Rockwall this summer!
Gary, whatever you do, please refrain from sending a PNW fart this way - would be a very un-cool thing for you to do, sir! Karl, the only snow I might see around here would be glorious snowflakes firing out of my car's a/c vents! Getcha suuuummmmm, bub!!! PS: will do about writing up my pimpolicious charging technique when I have a chance. |
Algernon, that is a really good idea and I plan to shamelessly copy you at some point! :)
