carrerarsr65
911 timing problem
timing seems to be 180degrees out z1 at bottom part of wheel
Old 10-19-2014, 11:03 AM
Under the radar
Trackrash's Avatar
Ooookaaaayyyy. Had the distributor out?
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-19-2014, 12:25 PM
carrerarsr65
k
no dizzy initial timimg afterrebuild
Old 10-19-2014, 10:48 PM
You bolted the crank fire 90 degrees off. Through 3.2 the pin on the crank is at 9 o'clock for TDC
On 3.6 the TDC pin is at 3 oclock
Bruce
Old 10-20-2014, 02:56 AM
