Distributor Recurve Question
My R.O.W. 3.0 engine has had an early (smaller gear) distributor fitted to it. (It looks like a carrera, but it's not)
Here's a picture of the distributor: http://forums.pelicanparts.com/uploa...1413652561.jpg It's got a little "target" on the side with "32" in it. I'm switching from CIS to carbs. Do I still need to recurve this distributor? And...will the car run without recurving it in the short term? Thanks! Michael |
It depends on what distributor you have. Some of them you can simply disconnect the vac and set more initial timing.
I typically re-curve them to a modified RS curve. Total curve comes in sooner. The "32" is a casting date. The part number is stamped on the other side.... 0 231 184 xxx |
That's great news. Thanks!
Sent from my iPhone using Tapatalk |
SC's had a counter-clockwise distributor rotation. Earlier distributors were set for clockwise rotation. Which way is yours spinning, and what is the number on it?
Type as in 930-XX |
He most likely has a carrera 3.0. It ran a 2.7 style distributor and was clockwise. Or, someone installed a cw gear on the crank.
You would not be able to install a cw distributor in an engine with a ccw crank gear |
| All times are GMT -8. The time now is 04:20 PM. |
