Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Distributor Recurve Question
My R.O.W. 3.0 engine has had an early (smaller gear) distributor fitted to it. (It looks like a carrera, but it's not)
Here's a picture of the distributor:
It's got a little "target" on the side with "32" in it.
I'm switching from CIS to carbs. Do I still need to recurve this distributor? And...will the car run without recurving it in the short term?
Thanks!
Michael
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 10-18-2014, 10:17 AM
BURN-BROS's Avatar
It depends on what distributor you have. Some of them you can simply disconnect the vac and set more initial timing.
I typically re-curve them to a modified RS curve. Total curve comes in sooner.
The "32" is a casting date.
The part number is stamped on the other side.... 0 231 184 xxx
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-18-2014, 10:29 AM
Rennch on YouTube
rennch's Avatar
That's great news. Thanks!
Michael O'Neal -
Old 10-19-2014, 07:20 AM
E Sully's Avatar
SC's had a counter-clockwise distributor rotation. Earlier distributors were set for clockwise rotation. Which way is yours spinning, and what is the number on it?
Ed
1973.5 T
Old 10-19-2014, 12:32 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Good point, Ed. Almost seems the engine type is a needed reference.
Type as in 930-XX
1981 911SC Targa
Old 10-19-2014, 02:15 PM
BURN-BROS's Avatar
He most likely has a carrera 3.0. It ran a 2.7 style distributor and was clockwise. Or, someone installed a cw gear on the crank.
You would not be able to install a cw distributor in an engine with a ccw crank gear
Old 10-19-2014, 02:58 PM
