Stranger on the Internet
patkeefe's Avatar
Clutch Pedal Spring
Hi all,
Due to a faulty right arm, I am having a bit of trouble pulling the spring onto the post of the clutch pedal. Anyone have a secret trick for levering this on? My usual helpers are away at college.
TIA
Pat
Patrick E. Keefe
78 SC
Old 10-19-2014, 08:56 AM
I've used a small Phillips head or pic thru the end and slid it down.
It can be frustrating because of the confined space and a bum arm.
Or, Pull your assistants out of college.
Priorities!
Matt
94 turbo 3.6
74 carrera RS race car
05 denali XL
"We are here to laugh at the odds and live our lives so well that Death will tremble to take us." Charles Bukowski
Old 10-19-2014, 09:23 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Removing the seats will give you more room as well.
'85 Carrera Targa
PCA/POC
Old 10-19-2014, 09:26 AM
With the spring out, slide a 1/8" thick spacer between each coil, tap them in with a hammer. This stretches the spring enough to allow the base end with the short loop to be put on over its post, place the pedal end on first, it has the longer length of looped wire.
You will need to pry each coil apart to insert the spacers, Orient them so they do not interfere and can be pulled out later!
I happened to have a bunch of 1.5" dia washers around that I used. No need to remove seats.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 10-19-2014, 11:37 AM
patkeefe's Avatar
Art, that is a great idea. I'll give it a try! My interior is gutted at the moment for RS carpet install, so I have all the room in the world.
Patrick E. Keefe
78 SC
Old 10-19-2014, 12:08 PM
patkeefe's Avatar
Art, that literally took two minutes. Thanks!
Patrick E. Keefe
78 SC
Old 10-19-2014, 12:52 PM
steely's Avatar
should that spring be rotated to clear the pedal? disregard me if I am wrong.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-19-2014, 03:01 PM
patkeefe's Avatar
I believe that is the correct orientation. It won't fit any other way, from what I can tell. It was a long time ago when I took it off...
Patrick E. Keefe
78 SC
Old 10-19-2014, 04:56 PM
steely's Avatar
gotcha - didn't mean to be a buzz kill :-)
Dan
Venetian Blue
Old 10-19-2014, 05:18 PM
