carrerarsr65
911 timing problem
timing seems to be 180degrees out z1 at bottom part of wheel
Under the radar
Ooookaaaayyyy. Had the distributor out?
carrerarsr65
k
no dizzy initial timimg afterrebuild
You bolted the crank fire 90 degrees off. Through 3.2 the pin on the crank is at 9 o'clock for TDC
On 3.6 the TDC pin is at 3 oclock Bruce |
