-   -   Quick question re: front wheel alignment. (http://forums.pelicanparts.com/porsche-911-technical-forum/834942-quick-question-re-front-wheel-alignment.html)
car-nut 10-23-2014 09:06 AM
Thank you Sal; got it!
My car is exactly same as yours (see Garage). I am running
Cheers
Zack
scarceller 10-23-2014 09:16 AM
In your garage pics the ride height looks good in the back but your front is way tall!
Shoot for 25.5" in the front if possible.
Or whatever the back is add 1/2" to that for the front. It's this 1/2" difference that looks nice, Bruce Anderson came up with this number yeas ago.
Love the car!
Cheers
Zack
car-nut 10-24-2014 07:44 AM
You are absolutely right SAL
I have already brought the front down. I have trouble giving is 0 or slight -ve camber. I am at 0.3 deg. +ve. hopefully tomorrow morning I will try to adjust it with a trick that I think it should work.
Cheers
Zack
scarceller 10-24-2014 07:49 AM
Zack,
Keep in mind that as you lower the ride height the bottom of the tire kicks out and the chamber starts going negative on it's own as you lower the height. So if right now you are at +0.3 then as you lower the chamber will start going negative.
I suggest you first lower it to the 25.5" fender lip height, then deal with the chamber.
Cheers
Zack
