Need Clutch recommendation for 911sc
Newbie looking for clutch recommendations for my 81 sc. Not a daily driver, but plan on using it as much as I can. Would like to keep it under $1000 for the parts if possible
Thanks Last edited by craigmakes3; 10-21-2014 at 03:23 PM.. Reason: typo |
Welcome to Pelican.
Honestly, you aren't going to be able to replace the clutch and components with new for under $100. Used parts may be less but if they are worth using they will cost some $$. Are you SURE you need to replace the clutch? You may just need to adjust the clutch cable. What sort of issues with the cluctch are you having?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Fleabit peanut monkey
I looked up a clutch kit for a 2005 Kia Rio on *********.com. It's $175.
No way for $100 on a 911. $700 for a Sachs power clutch (PP, T/O bearing, etc) No free lunch, sorry.
1981 911SC Targa |
He must've missed a zero there...
'82 SC cabriolet |
Maybe in 1981 you could get the parts for that price. You can check Ebay for a good price but you really don't want to cheap out and have to do it again.
Clutches are cheaper now than ever. A hundred bucks might buy a release bearing ......
Considering it takes a pro with a lift pretty much all day, it might take the better part of a weekend for a fairly good amateur wrench working on the floor, and considerably longer for a novice. This may not be the time to cheap out ... The Cap'n |
83 Targa
Option 1. Plan on the $100 AND then another $1500 for "while you're in there"
Option 2. Sell the car and buy a Miata |
abides.
The stock sachs clutch discs last a long time. I think I have over 100,000 miles on mine. You can find them for $131 if you look around.
Graham 1984 Carrera Targa |
If you want to do a clutch job and keep it "cheap" you can just replace the friction disk. When you replace the whole SACHS kit, you are looking at $800ish, only the friction disk (hopefully the other parts are still good) will run you about $250 iirc.
Good luck!!
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
Yikes - I meant $1000.
One leisurely weekend job on the driveway. If I am in a hurry, I can get it done in one Saturday providing I do not do anything else while I am in there. $1,000 is what it takes for a kit, plus your oil.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Although, I can tell you that there is always something while I am in there....
