87turbolook911's Avatar
Unhappy Fuel smell inside...
My car has a slight fuel smell all the time. I've checked the hoses by the filler neck and at the top of the fuel tank, no leaks there....removed the metal tray under the tank and there seems to be a leak before the fuel pump (very slight though) The only reason I know it's leaking is because the tray has a stain on it. No visible leaking.
Also when I turn on the A/C fan....the fuel smell is really strong. Where does the fan pull the air from?
Anything else I should check?
Thanks!
It's not just the cars...It's the people...
Porsche Club of America
NoVa / DC / MD Porschephiles
Porsche911FactoryTurbo-LookCars
Old 10-09-2002, 10:00 AM
Rick Lee's Avatar
It's been a while, but when we were troubleshooting my a/c blower fan, I seem to recall it was just above the fuel tank in the smuggler's box or just behind it. It sounds like your fuel smell is coming from the front of the car. It doesn't take much of a leak to make it smell. Next time your tank is real low on gas, jack her up and replace the line (costs less than $1.00) from the fuel pump to the tank, maybe snug up the banjo fitting on the fuel pump too. Since gas evaporates pretty fast, you may ought to check near the a/c blower motor immediately after a hard drive.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-09-2002, 10:30 AM
James_TX's Avatar
I would say check these 2 things...
Smugglers box. Maybe run some cleaner though there. If some gas somehow (stress somehow) go into the smugglers box this will cause the smell to come from there. If you look under the car you can see the drain hole from the smugglers box. I can see mine from just looking under the car. I dont know if it changed over the years.
Also check your gas cap. I resealed mine and it fixed it right away.
Good luck
James
"I found a moon rock in my nose"
'77 930
Old 10-09-2002, 01:46 PM
Senior Member
Doug Zielke's Avatar
Carreras are notorious fuel leakers!
Do a search before your car is BBQ'ed.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 10-09-2002, 03:00 PM
Cool
I'm w/James on the gas cap seal..my '77 had a couple of different cap seals available..not the easiest to pinpoint if it is the seal...also my 911 has a gas tank expansion tank under left fr fender w/a bunch of small vulnerable hoses going in/out.. I don't mind the smell of gear oil, but gas fumes can be a PIA/at least.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-09-2002, 03:01 PM
A Quiet Boom's Avatar
Good luck
This worked for me. Besides its a good reason to get a new cap if your's is showing it's age.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 10-09-2002, 04:26 PM
gumba's Avatar
Check the burb tank. There will be a line from the gas tank to a black plastic box behind the dash drivers side. This box cracks with age and that's where the smell comes from. The smell is stronger with a full tank. It costs about $65 from a dealer. It happened on both our '73's took me awhile to figure it out.
Old 10-09-2002, 06:01 PM
Also check the fuel level sender. The gasket there can dry out and allow some vapor to escape. Make sure there are no leaks from the pump area. Run the motor while the car is up in the air and check the area out closely
good luck
Old 10-09-2002, 06:16 PM
Doug E's Avatar
I'd suggest the fuel level cylinder as well. After pulling mine once I was getting a strong scent of gas and when I check the nuts on top they weren't as tight as they should have been. After re-tightening no more smell.
Doug
'81 SC Coupe
Old 10-09-2002, 07:50 PM
Senior Member
Have also had leaks twice from the large rubber hose that connects the fuel filler to the fuel tank. Worth checking while the carpet is pulled out.
JA
Old 10-09-2002, 08:02 PM
Thanks all...
I'll start hunting and will keep you posted on my findings...
Old 10-10-2002, 06:51 AM
