Differential preload 915
When measuring differential preload is it the static breakaway torque reading or the to keep it moving dynamic torque reading, that is the spec?
Old 11-07-2014, 07:46 AM
KTL KTL is offline
Schleprock
KTL's Avatar
You're measuring it while it's turning. You need a dial or beam-type wrench. Clicker type doesn't let you see how much torque it takes to keep it turning
How-To: Porsche 915 Transmission Repair Tutorial Part 5 - Porsche Wiki
Kevin L
'86 Carrera "Larry"
Old 11-07-2014, 08:30 AM
Geary's Avatar
That's an excellent question (and answer) .. one that I haven't seen asked before on Pelican. The term "breakaway torque" can be misleading (just as a memory pointer can) for this particular job.
Same deal when measuring diff bearing preload. The pointer will always show a deceivingly higher value than true dynamic turning torque. The needle may bounce around initially while turning, but do it for awhile, and the mean value will become evident.
Old 11-07-2014, 10:32 AM
Thanks, I guess I need more preload. I need to get new bearings first and recheck. I am using a beam torque wrench. Startup torque was about 20 in lbs but running was only 5.
Old 11-07-2014, 11:18 AM
Geary's Avatar
Ha ha .. I misread your initial post to say LSD breakaway. If you are measuring with used diff bearings, you may already be in the proper range.
Old 11-07-2014, 01:28 PM
