bcgreen's Avatar
Idle speed adj. screw?
On a 2.7 MFI engine where is the idle rpm adj. screw? Would you happen you have a picture?
My idle is a little low and I want to bring it up to correct spec., which is 900 rpm.
The engine is a '76, which is identical to the '73.
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-08-2014, 08:22 PM
tobluforu's Avatar
Idle is adjusted at the bottom of each stack. Screw out to increase idle on all 6, but you need a synch. Idle can also be adjusted via the pump, but if you car runs good, don't touch the ones on the pump.
Old 11-09-2014, 04:26 AM
