Idle speed adj. screw?
On a 2.7 MFI engine where is the idle rpm adj. screw? Would you happen you have a picture?
My idle is a little low and I want to bring it up to correct spec., which is 900 rpm. The engine is a '76, which is identical to the '73.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 11-08-2014 at 07:30 PM.. |
Idle is adjusted at the bottom of each stack. Screw out to increase idle on all 6, but you need a synch. Idle can also be adjusted via the pump, but if you car runs good, don't touch the ones on the pump.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 11-09-2014 at 03:31 AM.. |
