Idle hunting... why? How to fix?
Got '85 3.2 that's starting to hunt at idle. Pulses between 1,100 rpm and 1,200 a few times... then settles down to 1,000. Interested in what causes this. More interested in how to fix whatever's wrong.
EDITS: Only does when engine warmed. O2 sensor replaced about 18 months ago. |
On my 81 SC it was a combination of a bad O2 sensor, and fuel mixture. Also, the hunting at idle was continuous after the engine warmed up.
almost certainly the idle air blending valve. Pull it, clean it, clean the contacts on it. Mine was hunting in the same way and the above cured it - not instantly - but over the course of a few months of driving it got better and better to the point where I rarely see it any more.
I should back up and say I was so sure of my diagnosis in my case because It was a on a freshly rebuilt motor with all new o2, sensors etc etc. However if the symptoms exist when the motor is cold you can rule out the 02 as it is being ignored by the DME. |
A rich idle mixture will do this. It gets rich, revs up then the DME pulls the idle back down.
After the car warms up and uses the O2 sensor circuit it goes away. This symptom typically shows up when the temps drop down in the fall. There is quite a bit of documentation on this topic on the board. |
Take the ICV off and see if the valve moves when you shake it in your hand. If not, spray some carb cleaner in there to clean it up so it moves freely again. Reinstall and fire up the car. Mine was doing something similar so I did this and the hunting is gone.
To keep track of input, am listing suggested causes, recommended fixes, and relative links. Will move this forward as it's updated.
O2 sensor - replace (mine's not that old so will leave it be for time being.) Air blending valve - remove and clean (if hunting exists when engine is cold... 02 sensor can be ruled out) - I searched for "Air Blending Valve" and did not find fuel related info Idle mixture too rich - lean out idle mixture - Pelican Technical Article: The Motronic Engine Management System - 911 (1984-89) - ICV / Idle Control Valve - remove and test / clean - http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/330312-idle-valve.html |
When I had a the idle hunting problem it was a vacuum leak. One of the rubber hoses from the oil tank was cracked.
It is astonishing how dead steady the idle is on my car after the total rebuild. Most of that I attribute to the good seal of all the intake and fresh rubber on every connection. two of the intake bolts were just finger tight. How they got loose is a total mystery. I don't think that intake had ever been touched before. The ICV is a good place to start. I tried to clean mine in the past and had no luck on a long term fix. It is easy to replace so I put a new one on and that fixed it. I have had my 911 for 19 years and driven it myself for 90,000 miles so a lot of problems have popped up more than once and be fixed. They kinda run together in my brain. |
The ones the hold the intake runners down. There are two on each cylinder sealed with a individual gasket.
To be more specific, if you rotate the ICV in your hand like it's a screwdriver and you're quickly turning it, you should see the valve rotate in there. Mine seemed pretty sticky, and there was a good amount of black "soot" in there. So I sprayed some carb cleaner to clean it out. I could then rotate it, and the valve was way more free and "floppy" in there. So in my mind, the DME was trying to move the ICV during idle, but the ICV was slow to react due to the valve being sticky, which was responsible for my hunting. The nice thing about checking the ICV is it's free :) |
My mechanic adjusted the mixture, so I am not really sure what they did. I did have to recently take to a mechanic to adjust the mixture again, as it was stalling and bucking between 2000-3000 RPM. I watched him - he took off the airbox cover, and used a ratchet at something near the fuel distributor. He also adjusted the idle screw and it ran great. Took him 5 minutes and it passed smog too!
Use the o2 sensor perhaps? paging scarceller? |
I would bet the Idle Speed Valve, or ISV. Others referred to it as the blending valve above. On a cold engine, the DME tells it to open, adds more air to the engine. as the car warms up, the idle starts to raise, the DME tells the ISV to close some. If it doesn't, the idle gets higher, car gets warmer, until it hits the DME limit of about 1200 rpm. DME cuts the signal, maybe to the injectors, I am not sure. The idle drops, signal is restored, idle increases cause the ISV is still stuck open, repeat.
Could be other things, like a vacuum / intake leak. What is happening is the idle gets too high because of the extra air, and the ISV is closed all the way, so it can't help. Pulsing starts. Since you said it will eventually stop pulsing, and a vacuum leak would stay leaking, I am pretty sure it is a sticky ISV. |
Sorry plz ignore 81' 911sc widebody |
85 3.2 with the factory chip should idle around 800 rpm. If you are idling at 1k and haven't made any adjustments I would put my money on a vacuum leak. Could be as simple as a cracked hose or loose intake runner. Hopefully you don't have to replace intake runner gaskets. Lots of info if you search 'idle bounce'. |
Most of the big things I'd check have been mentioned:
- Intake bolts to 18 ft/lbs (the gaskets under them can be cracked so not a sure fix.) - Cracked hoses. After this many years there is almost certainly toasty hoses. - ICV is possible. A number of articles on checking that. - One I haven't seen is the cylinder head temp sensor. Most important is TEST not REPLACE. (Always drives me crazy to watch someone dueling with their car blindfolded with shotguns.) A good test for the intake is to use an infrared thermometer gun to read the exhaust port temps after startup. A vacuum leak in the port can cause a port to read cold. Full throttle it will run fine. ------- Helpful hints for anyone that needs to replace their intake gaskets... - There are 2 gaskets for each port. One below and one above the plastic spacer. - The plastic spacer will need to be replaced if you open it up. At this age they are crumbling. ------------ Oh yeah... And as mentioned before: Ignore the advice from people referring to cars 1983 or before, or referring to "SC" or CIS". Their cars are completely different and are not electronically managed. |
Yea, it was a weird mystery how two of the bolts that hold the intake down could be loose. The others all came off with that nice snap. Two were just finger tight.
Looks like you caught this before I posted. No worries. |
Nice deduction at the end Tech. Suggests where to start. TY for input. |
http://forums.pelicanparts.com/uploa...1415138175.jpg Evidence is building for sticky ICV. |
Updated Checklist:
To keep track of info, am listing suggested causes, tests, recommended fixes, and relative links. Will move this forward as it's updated. Please advise correction(s) if you see anything wrong. O2 sensor - Test (how?) Air blending valve - remove and clean (if hunting exists when engine is cold... 02 sensor can be ruled out) - searched for Air Blending Valve and did not find fuel related info. Are we talking ICV/ISV here? Idle mixture too rich - lean out idle mixture - Pelican Technical Article: The Motronic Engine Management System - 911 (1984-89) - ICV - remove and test / clean - http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/330312-idle-valve.html Intake manifold bolt tightness - check tightness (18 ftlbs --- not sure what years this applies to). Good test for the intake is to use an infrared thermometer gun to read the exhaust port temps after startup. A vacuum leak in the port can cause a port to read cold. Full throttle it will run fine. Intake manifold gaskets - Helpful hints for anyone that needs to replace their intake gaskets... - There are 2 gaskets for each port. One below and one above the plastic spacer. - The plastic spacer will need to be replaced if you open it up. At this age they are crumbling. TY for input guys. |
Tomorrow am into ICV/ISV and will check intake bolts.
Worked with DME before,ICV failure is rare and yes they can be cleaned and will work again,check for a buzzing noise with the key on if not don't dive in and buy a new one cause they are $$$$ new,check the plug on to it first,they do get old and don't connect properly,the result of this is a rolling idle from say 900 to 1200rpm or stalling after coming off throttle.
If you have air leaks the ICV gets out of running range and your idle will increase past what it will compensate for,as mentioned check the inlet manifolds for leaks. O2 sensor normally won't effect idle but will cause a rich (default) condition after normal driving and increased fuel consumption,make sure your replacement one is exactly speced for your model and not a cheap universal one,ask me how I know:rolleyes: Think there should be a new tech book called "101 places for air leaks on EFI systems" because IMO this is the primary cause of issues. |
The bad intake gaskets were kind of a blessing in disguise. I had to take off the intake and I discovered a couple cracked vacuum lines, some lines hardened to the point where they cracked on reassembly, and the biggie was that the crimped connections in the fuel lines would spin like they were bearings. :eek: Glad I caught that before the Car-B-Que. An intake teardown to replace rubber parts is a good preventative measure on cars of this age. |
It does have a fast idle when cold. Quote:
Sal is the expert on all of this. |
Car-B-Que. Saw one some years ago on highway. 911 engine fire off to side of road and guy obviously had no extinguisher---just standing back watching it burn. Sinking feeling. With you on rubber replacement Wayne. |
Good note on gasket access Rick. Am questioning whether I want to go that far at this time. Have other projects lined up so am hoping this idle hunt will be a quick resolve. |
Today...
Pulled ICV and removed case to check guts. Rotation doesn't seem sticky but not sure how delicate the movement of valve is. NOTE: Valve does not go round and round. It opens in one direction... and reverses to close. Here's looking into valve... open then closed. A bit of gunk can be seen on closed valve. http://forums.pelicanparts.com/uploa...1415229388.jpg Brake cleaned valve area. O-ring is in good, pliable condition. So are hoses. Now am going to clean crud off electricals... http://forums.pelicanparts.com/uploa...1415229472.jpg Inside housing are 3 contacts. Will bend them in slightly towards center. Beyond contacts there's floating plastic shield. That can fall out if not careful. http://forums.pelicanparts.com/uploa...1415229575.jpg Obvious weak link in this area (in my engine) is top hose connection to intake plenum. That connection came apart with very little effort. Am going to replace the 2 crimped hose clamps there with screw clamps asap. http://forums.pelicanparts.com/uploa...1415229701.jpg Went for 20 mile city drive afterwards. Did a couple of "Pablo variations" ...no more hunting. RPM is now near 800. http://forums.pelicanparts.com/uploa...1415229917.jpg Had planned to check intake manifold bolts today but ran out of time. Is on tomorrow's menu. |
Fix = Clean ICV valve passageway with brake cleaner, slightly bend in 3 internal contacts, clean o-ring.
Also replaced 2 old crimp clamps that make connection at air intake plenum seen below (because this connection pulled out far to easy.) This was done after hunting was corrected so not necessary at moment but no need to leave it to loosen further. http://forums.pelicanparts.com/uploa...1415317458.jpg http://forums.pelicanparts.com/uploa...1415317476.jpg Installed screw clamps but they don't fit visually compared to (solid) stock clamps. Will sort this out later. http://forums.pelicanparts.com/uploa...1415317596.jpg Considered checking intake manifold bolt tightness but to access all of them... it's no small undertaking. So, sampled #4's intake bolts. Definitely under 18 ft lbs. Left bolts where they were. Will deal with this come next year's case split. TY for input guys. http://forums.pelicanparts.com/support/smileys/wat6.gif |
Great news, good luck with your alignment work!
I would also add that you really don't want to mess with the mixture. All that will do is mask the real problem. As stated before, ICV, and then vacuum leaks. I tightened down all my manifold bolts, chased down all my leaks and then bought a used(know good) ICV, and replaced my high pressure fuel lines. Now my idle is fine.
I think too many people want to dive in and start monkeying with the mixture settings. Not the best way to go in my humble opinion. |
