charles
Replace H4 headlight lens
Driving home this weekend I stop and the stop sign 2 blocks from home and hear 'pink, crackle crackle'. Get out of car and the headlight assembly lay on the road - somehow, the screw holding it in at the base must have backed out as it was no where to be found?
I have a replacement lens ordered - but looking at the headlight assembly it looks like you have to disassemble the entire unit to replace the lens?
Is there an easy way to do this?
Old 02-02-2015, 05:20 PM
There are some funky metal spring clips that hold the glass in place against the housing. Take them off one at a time and pay attention to the orientation. Not rocket science but mine were aggravating and took a few tries to get them all back on spaced correctly.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 02-02-2015, 05:27 PM
wwest's Avatar
Take GOOD pictures of the way and type of clips used first.
Old 02-02-2015, 06:05 PM
redturbo911's Avatar
You might want toreplace the seal to save yourself from any moisture in the future. Ask me how I know? Lol.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 02-02-2015, 06:29 PM
Registered Cruiser
jorian's Avatar
Saw this happen at a local autocross a few years back. Bummer. When you replace the lens it's a good time to attach a lanyard/zip tie from the lens to the inside bucket to prevent, well you know...
Do both sides while yor in there. The little screw is totally inadequate to hold that assembly in place.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 02-02-2015, 07:00 PM
Banned but not out, yet..
RSBob's Avatar
Before you reinstall the whole assembly, use a large zip tie secured to the H4 assembly and the what ever you can find in the headlight bucket - even the wire loom. If it comes loose, it won't hit the ground.
Old 02-02-2015, 07:04 PM
Formerly known as Syzygy
Canada Kev's Avatar
+1
And some safety glasses are probably a good idea as those clips can spring out and fly across the room. Or into your eye.
Kevin
Old 02-02-2015, 07:45 PM
Spiderman
Jesse16's Avatar
++1 on safety glasses. Don't discount the possibility of flying springs. I had one go 20' across my garage and under a cabinet, PIA to find. Very old school headlight retention but they do work.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 02-03-2015, 05:57 AM
Better yet, remove your other headlight, place side by side, and use it as a guide on spring clip replacement. Makes it real simple.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 02-03-2015, 06:06 AM
wwest's Avatar
While you're in there projector Hi/lo HIDs are readily available on Ebay.
Old 02-03-2015, 10:46 AM
Lights
Tell us more about this please.
Tony
Old 02-03-2015, 03:41 PM
charles
Thanks for replies.
Is it necessary to unscrew all of the adjuster screws in order to pull the reflector off and slip new lens in, or is there an easier way?
thanks
Old 02-07-2015, 07:34 AM
Functionista
manbridge 74's Avatar
I generally pull the rubber grommets off with screws and lift lens off. You can make new rubber pieces out of vacuum line if needed.
Also the factory retaining method is not THAT bad as long as all hardware/seals are in good condition and metal tabs and H4 rings are properly formed. Some additional retaining is a good precaution as these are 40+ years old. I also like to try and pull them off by hand when done mounting. If they shift at all or lift off the top tab some more adjustment is required.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-07-2015, 08:06 AM
FYI, that's an H1 assembly, not an H4, so if that's your light assembly you need an H1 glass. Same dynamic in your work.
Previous post to mine indicates that you pull the adjuster metal "arrow" out of the rubber grommet, or remove the grommet entirely and then replace as he indicated.
Individual springs are available from the VW guys for cheap vs a Porsche supplier.
Have fun!
http://www.autoforeignservices.com/
57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc.
Old 02-07-2015, 09:21 AM
charles
Thanks for method for replacing lens, and for pointing out it is an H1 not h4 headlight - time to order a lens.
Charles
Old 02-08-2015, 03:39 PM
jaudette3's Avatar
I restore H1's and they can be a little tricky. The screw that's attached to the spring coil will probably be impossible to remove. But you can just leave it attached to replace a lens. Pull the prongs on the two adjustment screws that have them out of the small rubber tubes on the large reflector. Then back off the other adjustment screw that screws into the high beam adjuster. Remove the spring clips and you can then wriggle the housing away from the lens and chrome trim ring. PM me if you have any problems and I'll try to help.
John Audette - Porsche Lighting Specialist
Vintage Porsche Light Restoration - LED Headlights
Site: www.AudetteCollection.com
Store: www.911Bestinclass.com
Old 02-10-2015, 04:13 PM
charles
Thanks John
I hope to tackle it this weekend, and will ping you if I get stuck.
Charles
Old 02-10-2015, 05:38 PM
