ignition coil and CDI test
Is there is a way to test the ignition coil and also to CDI box . My 1980 911 wont start has no spark at the spark plugs. I am scared to mess with this as I am told it will shock you
Thanks |
Eva
This doc and a m
This doc and a volt meter recently helped me diagnose and a friend rebuilt my CDI. If you're poking around the coil with the key on or engine cranking, it's likely to get a shock.
If you follow this the testing is at the CDI plug which will not harm you. If your coil is bad, disconnect battery before remove/replace. Have fun, it's truly simple once you grasp it.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
I just took my CDI to a local Porsche shop, the owner dropped it in one of his cars and it fired right up.
1982 911 Targa, 3.0L ROW with Webers |
Do the tests above from 911SauCy.
May be the "green wire" take a look at this thread A not so straight forward Green Wire install which has links to solution help. Jay |
first question should be ........ is your coil silver ?
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Eva
So you had a bad coil or trigger wire? Which one.
