ignition coil and CDI test
Is there is a way to test the ignition coil and also to CDI box . My 1980 911 wont start has no spark at the spark plugs. I am scared to mess with this as I am told it will shock you
Old 11-25-2014, 07:46 AM
Eva
911SauCy's Avatar
This doc and a m
This doc and a volt meter recently helped me diagnose and a friend rebuilt my CDI. If you're poking around the coil with the key on or engine cranking, it's likely to get a shock.
If you follow this the testing is at the CDI plug which will not harm you. If your coil is bad, disconnect battery before remove/replace.
Have fun, it's truly simple once you grasp it.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 11-25-2014, 08:06 AM
I just took my CDI to a local Porsche shop, the owner dropped it in one of his cars and it fired right up.
1982 911 Targa, 3.0L ROW with Webers
Old 11-25-2014, 08:26 AM
jtfreels's Avatar
Do the tests above from 911SauCy.
May be the "green wire" take a look at this thread
A not so straight forward Green Wire install
which has links to solution help.
Jay
Old 11-25-2014, 08:55 AM
theiceman's Avatar
first question should be ........ is your coil silver ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-25-2014, 10:42 AM
Eva
911SauCy's Avatar
So you had a bad coil or trigger wire? Which one.
Old 11-25-2014, 11:16 AM
