83 911 Production Cab #10
When I did mine I use Big-Sert kit # 5215 also made by Time-Sert.
As the name imply, it heavy duty. http://www.amazon.com/gp/product/B003QB5I52/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 11-08-2014 at 03:07 PM.. Reason: Size Correction |
I made this myself, but if you want stock thread size, it's M12x1.5:
Kit Nr. 5215
Roland 930 Turbo '81 Too many modifications to list |
Absolutely correct. I check my order and it was the M12x1.5 kit.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
From what I understand, bigserts are to fix incorrectly done timesert jobs.
I made this because there was a not rectangular time sert, but I did not knew until changing from rubber to solid mounts. Here you find some details:
++ BIG-SERT Oversized thread repair kits ++ thread repair kits for oversized holes, previously repaired threads oversized holes of course no need if you only have a damaged stock thread. then a normal time sert is enough, or a helicoil too, depending on what you prefer. But if like my case, the only solution is a big sert
![]() But are you saying You made the kit (i.e., you invented it?). If you did, glad to have an inventor as part of the Pelican family. ![]() Quote:
oh no! I did not made the kit, I bought it and made the job. Sorry for my poor language skills here
![]() ![]() Anyways, so far my analysis regarding needing longer bolts is correct. I could not find 65 mm bolts today but I did find a 70mm. I am also waiting for longer insert. I will redrill and retap again hoping that this 4th timesert job will not result to having to do a BigSert job. ![]() These kits cost!!!!!!! Perhaps if I end up needing a BigSert job, someone can rent me their BigSert kit. ![]() |
How thick are the washers?
cab83, I did some calculations using your M12 x 1.5 x 60 mm. OEM transmission mount thickness approx............................. 39 mm Protruding length of bolt.............................................. ........ 6 mm Remaining length used by washers........................................ 15 mm (?) Total............................................. ................................. 60 mm What thickness (mm) are your washers? Could you measure the thickness (mm) of the transmission mounts? Thanks, Tony |
The washer for the bolt is 2mm. Don't forget that the big washer, the one that covers the rubber housing (60mm), is also about 2 mm.
The xmission mount is about 39mm. Lastly, I believe that the last 8mm from the tip of the cone is actually useless. ![]() Quote:
If my bolts are actually too short, I wonder how many of us are out there with these short bolts.
I am not an engineer, but I would think that since these bolts are barely inside the female thread, perhaps all the shaking, stress and pressure of the engine/tranny weight result to damaged threads---and perhaps, if this theory is true, we should stop blaming our mechanics. ![]() |
In cases like this, my goal is to get a length of 1.5 times x diameter, more does not add any strength. Here it's 18mm then
Rent my kit is possible, but the fact I am in Switzerland does not make this realistic regarding the shipping costs...
Well, I believe that my big-sert job was a perfect fit. Very tight.
Just fyi, the drill for the big-sert is a lot longer than the time-sert. This means that your car really needs to be way way up higher to have leverage. I also use the tap die guide as a drill guide just to ensure I am plumb and straight. I used aluminum foil to enlarge the diameter. The tap guide is highly recommended for this job (for both timesert and big sert). I also fabricated tranny mounting bolts since the factory ones that I have were "too short." With the fabricated bolts, I definitely know that I have 16mm worth of threads holding the tranny. ![]() ![]() ![]() |
Use a helicoil kit like they use on aircraft engines. Timeserts are weird! No-one uses them in the UK.
Interesting. From what I have read, time-Serts are a lot better. Perhaps I should re-read and update myself.
I'll wait for others to chime in also. Quote:
Thread Tools | |
Rate This Thread | |
