Noel's Avatar
Clicking from dash (Varies with wheel speed)?
Hi guys,
I had my 1980SC out for a pre-track weekend test drive and notice a clicking noise coming from behind the dash that varied with the speed of the car. I thought bearing at first, but this is not a bearing noise. Any ideas?
Speedo?
Thanks,
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 04-12-2004, 08:54 AM
You do not have permissi
john70t's Avatar
Speedo cable would my guess. Before taking it out and re-routing it and lubing it, try turning the gauge clockwise. Does the needle bounce? Could also be the plastic odometer gears inside which have been known to go bad.
Old 04-12-2004, 09:12 AM
1982911sc's Avatar
I bet it is your o2 sencor counter. Do a search here for O2 sensor or oxygen sensor. It is a little black box that counts its way down from 30,000 mile telling you it is time to change your 02 sensor (light on dash goes on). You can tape up the wires and it will not count anymore or click anymore! It is located behind your speedo or tac, I forget which one.
944 TURBO!!!!
1982 911 SC Targa (loved but sold!)
2005 Cobalt SS (0-60 in 6.1!!)
2003 BMW 325i ex got in divorce
1969 912 Coupe (sold)
PCA Member
Old 04-12-2004, 09:14 AM
maxnine11's Avatar
John 70t, 80 SC=electronic speedo= no cable.
I will bet that it is the counter for the Oxygen Sensor light.
Do a search on what it is for and how to disable it.
My car made the exact same ticking sound, dependant on speed.
max
max
Old 04-12-2004, 09:16 AM
Noel's Avatar
Thanks guys, I will look into to it tonight. I love this board!!!
Old 04-12-2004, 10:04 AM
slater's Avatar
two words- dash gnome
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 04-12-2004, 12:44 PM
Senior Member
Doug Zielke's Avatar
Max is on target!
It's the O2 milage counter. Easily silenced.
BTW, Max....All your friends up North are hoping to see you again at this years SCWDP Round-Up.....
http://members.shaw.ca/zielke/roundup.html
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-12-2004, 01:42 PM
GB83SC's Avatar
Pull your spedo out, look down and to the right, you will see the small black box. I cut the brown wire on my car, and no more clicking sound.
Good luck.
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 04-12-2004, 02:03 PM
I agree that it is likely the O2 counter. My 81 SC does it too.
An easy way to check is to listen for the clicking, and then with the clicking occuring, turn off the ignition.... (be careful of the steering wheel lock!!) If it is the O2 counter, it will stop.
From the posts, it seems like the preferred way to disable it is to cut the brown (ground) wire to the 'little black box' located in the dash.
'81 SC Targa - "Hellblau" Blue
Old 04-12-2004, 10:58 PM
Noel's Avatar
You guys were on target, I pulled the Speedo last night and pressed the reset button and the noise it made while resetting was similar. I will know for sure when I drive it on Friday on my way to Mid-Ohio. I decided to merely reset it as I only drive about 2-3K miles per year and it will be over ten years until I need to deal with it again (30K mile intervals per the owners manual).
Interestingly, my light for the Ox sensor was burned out so that explains why the light wasn't on also.
THanks again for the help.
Noel
Old 04-13-2004, 06:46 AM
JC930's Avatar
If it's not a continous clicking and more like a plastic popping it's the plastic on the gauge face popping. Just does it with temp. change.
Just a common thing with p-cars.
77' 930 turbo carrera silver SOLD
03' SL500 Mercedes Benz white
06' GMC Yukon Danali white
15' LTZ Chevy Suburban black
07' 997 tt black
Old 04-13-2004, 07:57 AM
Thank you for all for the information. Turned off the ingition this morning while rolling slowly and click went away. Will be disabling counter shortly.
Old 11-06-2014, 08:58 AM
wannabee wannabee
WIL84911's Avatar
Does this appy to 3.2's as well? I'm been hearing an occasional pop in the dash area.
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 11-06-2014, 05:03 PM
