Details to Modify G50 drive Flanges
Hi all, does anyone have exact details regarding the modifications neccesary to a a G50 108mm diameter fine spline gearbox flange to fit a 915 box ?.
I've found lots of refrencese but no detail.
Old 05-20-2014, 03:59 AM
I'll bump this lonely thread as I have the same question.
Old 11-07-2014, 08:09 PM
If you are replacing 100mm fine spline output flanges with 108mm flanges and you can't find the 915 version, then, as mentioned, you can use the G50 108mm flange from the '87-'89 G50. The flanges are identical except the G50 spline shaft is a little longer. I would suppose you could take your old 100mm fine spline and the G50 108mm to a machine shop and have them milled to the same length. Seems pretty easy.
As you probably already know, the '85 1/2-'86 915 108mm flanges are almost "unobtanium" unless you spend the BIG bucks for new.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 11-07-2014, 09:55 PM
