sp_cs's Avatar
3.4 single plug = upgrade coil?
Folks
I've been running a 3.4 conversion for several years now, but have always had a slight doubt whether the standard motronic coil was up to the job.
I'm running a single plug setup with remapped motronic and 98mm Mahle p and c's, and wondering whether I'd benefit from a coil 'upgrade' eg nology pfc-m70
I have just bought a standard replacement Bosch coil but would sell this on if the nology (or other) is deemed worthwhile.
Thoughts please?
Shirish
1987 Carrera, Granite Green
Old 11-19-2014, 08:47 AM
Diss Member
Quicksilver's Avatar
The diameter of the cylinder has nothing to do with what is needed to get the spark plug to fire.
(Well, in theory if it increased cylinder pressure when the spark is jumping the higher pressure could inhibit the spark event but that kind of pressure would ensure that the car would detonate too.)
The whole spark thing is the biggest place where physics leaves people's brains and voodoo comes in for a dance.
- A basic truth -> "You can't get more burnt then burnt."
If you started the fire in the combustion chamber at the correct point in the Otto cycle then the ignition system had done its whole job.
The only meaningful changes you can make are:
- When the spark fires
- Where the spark fires (different length of plug nose or moving the plug location)
- Temperature range of the plug (too cold so if fouls, just right so it works, to hot so pre-ignition starts)
- Multiple ignition points (twin plug. NOT multi gap plugs)
- Changes to components to increase their reliability
It sounds like you are lighting the fire. My question would be "Is the advance curve correct for the engine?" or "How can I give this thing the twin plugging it really wants?"
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-19-2014, 09:08 AM
Originally Posted by sp_cs View Post
Folks
Thoughts please?
Your stock coil is MORE than enough for the job and I'd recommend not wasting money on junk like Nology.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-19-2014, 11:11 AM
sp_cs's Avatar
Thanks both, looks like I'll stick with standard! Q - do coils wear over time, or are they considered 'digital', i.e. they work or they don't?
Old 11-19-2014, 12:20 PM
Bird911's Avatar
What about a "Direct fire unit" or direct ignition system like the one from Electromotive that claim to provide a stronger and longer spark duration. Would this help the combustion with better timing, and help to avoid misfires ?
Your thoughts please,
Hugo
Old 11-19-2014, 05:43 PM
dos531's Avatar
Stock coil on mine works fine.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 11-19-2014, 05:56 PM
