89 911 brake bleeding
Has anyone ever bled their brakes through the Fuchs without removing the wheels? Thanks guys
"O"man(are we in trouble)
Not me.
i have from the backside of the wheel. not sure there's enough room to turn a wrench through the wheel opening.
Don't be lazy. Jack the car up, remove the wheel and flush the brake fluid the correct way.
Seriously, you will spend more time messing around with trying to get inside the wheel housing, fidgeting with snaking the bleeder hose onto the caliper, you will wish you just did it the right way. But if you must, have at it...
Mike '89 CARRERA #402 |
Member 911 Anonymous
Give it a try and let us know how it went
I know guys with truck do it on the floor, would be interest to see if you can pull it off. Pics please. Remember to pinch off the G50 clutch line :-P
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Why would G50 owners need to pinch off their clutch line? I the reservoir was filled during the process, why is that needed?
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Spiderman
If using a pressure bleeder, have to pinch off the reservoir vent. Not clutch line that I know of.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
cycling has-been
Are you aware of the damage that brake fluid will do the finish on your Fuchs?
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
jlex, I think what DRACO meant was the reservoir vent tube.
