-   -   question on how to replace rear shocks on 4 post lift, without bridge jack (http://forums.pelicanparts.com/porsche-911-technical-forum/838126-question-how-replace-rear-shocks-4-post-lift-without-bridge-jack.html)
rnln 11-11-2014 02:07 AM
1- undo the top nut
2- undo the bottom bolt
3- swap the shock
4- tighten the bottom bolt and top nut
5- done
Am I correct? Or must I put the car on jackstand?
Lyle O 11-11-2014 03:13 AM
That's pretty much it. However, you'll have to make sure the shock is compressed enough to fit in there, and that's a little tough when the suspension is loaded. Jacking it up helps a lot... Good luck.
Jcslocum 11-11-2014 04:34 AM
6-Have a really cold BEER!
rnln 11-21-2014 11:03 PM
That means I can rely on the torsion bars and spring plates for couple hours right?
Thanks guys.
mnez 11-22-2014 04:42 AM
Yes.
DRACO A5OG 11-22-2014 09:33 AM
If you need help, call me :P
FPB111 11-22-2014 11:23 AM
Thanks guys.
??You could drive it without the shocks if you wanted to have a fun time "bounding" down the road.
If it is a drive on 4 post lift you could probably unload the suspension some by jacking at the jack point with your stock jack.
rnln 11-24-2014 12:03 AM
thanks guys.
Draco, will do buddy :)
I also need to do oil change. Been doing it myself but suddenly forgot how many quarts now, 10 or 12? :lol: I didn't drive the car much, so I didn't do it for a year or so. Maybe getting too old now :(
DRACO A5OG 11-24-2014 01:27 AM
10, bring her to operating temps and top off, young man :D
